Gas Leak
07-06-2007, 07:17
Gas Leak
This morning I discovered a gas leak! The unit on the LPG tank (which
has a glass gauge) was leaking. I tightened the four screws and it appears to have stopped leaking. I tested it with soapy water and around all the connections and all seems to be well. I can still smell gas a couple of hours since I "fixed" the leak. Can anyone advise? 1982 FC 35 |
07-06-2007, 08:21
Gas Leak
I had ( or have) the same problem with my tank. It seems to come and
go. The guage has both a gasket and an o-ring. In order to replace them you have to emty your tank. It is very hard to obtain the parts. No RV dealer or propane shop will sell to you unless you are a licensed gas fitter. I di not try BB. Bruce 1988 FC35 |
07-06-2007, 08:32
Gas Leak
Hi ????????
There area areas that can be worked around, this is not one of them. Get a certified Tech out to replace the remote gauge and sender as well as all gaskets and test the ASME tank fittings. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 07:17 PM 7/6/2007 +0000, you wrote: >This morning I discovered a gas leak! The unit on the LPG tank (which >has a glass gauge) was leaking. I tightened the four screws and it >appears to have stopped leaking. I tested it with soapy water and >around all the connections and all seems to be well. I can still smell >gas a couple of hours since I "fixed" the leak. Can anyone advise? > >1982 FC 35 > > |
07-06-2007, 10:15
Gas Leak
I was told one time to always be sure to open or close the valve all the way.
If I had a propane gas leak I would close the valve all the way and seek help from a qualified and certified professional. Howard, Sowega, 86 PT40 > > From: "birdshill123" > Date: 2007/07/06 Fri PM 04:21:50 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Gas Leak > > I had ( or have) the same problem with my tank. It seems to come and > go. The guage has both a gasket and an o-ring. In order to replace them > you have to emty your tank. It is very hard to obtain the parts. No RV > dealer or propane shop will sell to you unless you are a licensed gas > fitter. I di not try BB. > > Bruce > 1988 FC35 > > > |
07-06-2007, 12:02
Gas Leak
I agree with the previous posts, get a professional to check it out.
It will cost less than your life insurance payment, if you get my drift! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" wrote: > > This morning I discovered a gas leak! The unit on the LPG tank (which > has a glass gauge) was leaking. I tightened the four screws and it > appears to have stopped leaking. I tested it with soapy water and > around all the connections and all seems to be well. I can still smell > gas a couple of hours since I "fixed" the leak. Can anyone advise? > > 1982 FC 35 > |
