30 amp VS 50 amp
07-08-2007, 04:29
30 amp VS 50 amp
John: Our 73 had the Onan 6.5 and worked Ok for a couple of years,
then the engine "ate" a valve seat. We replaced it with a 5,5 Onan, and it will work both Airs OK, but kicks the breaker when the microwave, or vacume is used.. The 5.5 Onan has a ROBIN engine made by Subuaru... We had the Gen-Shore power rotoswitch replaced by an automatic changeover switch. a new rotoswitch is near $400.! Our old Toyota had a neat arrangment. The Shore power cord was permanatly attached to the RV, & the Gen was hardwired to a Shorepower type receptical. Then we simply plugged the shorepower cord plug into the campground power, or into the recipital in the coach, as needed.. SIMPLE !! Check with CampWorld about replacing the bad A/C. They have one that is slightly larger (15Kbtu) and uses slightly less power than the 13K btu unit. As for a new shorepower cord, or parts, check with your friendly Marine (Boat) store, but be aware the prices there will make Bluebird parts look cheap !! Jack Smith 1973 FC 31 391 HOT! SoCal --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > My 1973 FC has a 30 amp service, or at least that's what is stamped on > the shore cord. This bus has two air conditioners front and back. The > previous owner never used the back one (mainly because it was > inoperable) I have ordered and intend to have both up and running. My > question? Am I going to be ok with 30 amp service? This bus was > delivered new with two air conditioners I am pretty certain but every > RV I have ever seen with two airs was always 50 amps. And I guess I > could be wrong but there are two there now anyways. What if anything > needs to be done? > > The previous questions about the weather striping and the refrig worked > out. A trip to Lowe's took care of the air leaks and the refrig fixed > its self. I was about to dig into it and I tried one more time and the > gas took right off. Don't you just love it when something fixes > itself? > > John Heckman > central Pa > 1973 31ft FC > |
07-09-2007, 07:59
30 amp VS 50 amp
In searching for a 50 amp extension cord for my coach, I see that
some eBay sellers are offering 50 amp cords with three 6 gauge wires and one 8 gauge wire (presumably the ground wire). This corresponds to some "50 amp range cords" I've seen in home centers with the same size wires. What is difficult is finding 50 amp Romex in the 6 gauge size. (I needed a couple of feet of 6 gauge wire to wire in the Progressive Industries surge protector I got for my coach...) I had to purchase individual wires (in suitable colors) as the home center did not carry any such Romex. I have had no trouble getting 30 amp (10 gauge) wire for additions to my home wiring system. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 8, 2007, at 6:47 AM, bubblerboy64 wrote: > Thanks for the information on this subject. The ONAN is rated at > 6500 watts not 8500. I would think if all is well it should handle > the two air conditioners. I'll have to consider the conversion to 50 > amp service. I was not aware that 6 gauge wire for shore power was > available. And here I thought 10 gaurge large. JOhn Heckman > Central Pa > '73 FC > > > <snip> [Non-text portions of this message have been removed] |
07-09-2007, 08:41
30 amp VS 50 amp
Next time Pete, just go to a Home Depot or an electrical product
supplier and ask for 6/4 SWOO cord. They sell it by the foot. What I used for my new 50 foot shore power cord. Also, Ernie Ekberg is making him one too. It comes in other sizes such as 8/4 10/4 12/4 12/3 etc. Terry Neal Bozeman, MT 82PT40 74FC34 Pete Masterson wrote: > In searching for a 50 amp extension cord for my coach, I see that > some eBay sellers are offering 50 amp cords with three 6 gauge wires > and one 8 gauge wire (presumably the ground wire). This corresponds > to some "50 amp range cords" I've seen in home centers with the same > size wires. > > What is difficult is finding 50 amp Romex in the 6 gauge size. (I > needed a couple of feet of 6 gauge wire to wire in the Progressive > Industries surge protector I got for my coach...) I had to purchase > individual wires (in suitable colors) as the home center did not > carry any such Romex. > > I have had no trouble getting 30 amp (10 gauge) wire for additions to > my home wiring system. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > On Jul 8, 2007, at 6:47 AM, bubblerboy64 wrote: > > > Thanks for the information on this subject. The ONAN is rated at > > 6500 watts not 8500. I would think if all is well it should handle > > the two air conditioners. I'll have to consider the conversion to 50 > > amp service. I was not aware that 6 gauge wire for shore power was > > available. And here I thought 10 gaurge large. JOhn Heckman > > Central Pa > > '73 FC > > > > > > > <snip> > > [Non-text portions of this message have been removed] > > |
07-09-2007, 09:53
30 amp VS 50 amp
Pete,
I have bought that 6guage, 4 conductor cable at both Home Depot and Lowe's. They both had it. However what they have is for interior wiring and direct burial cable. It is good for running inside your home from the breaker box to and external 4 way plug. But if your intention is to run from a shoreline plug to the motorhome you would want a more flexible cable and that would not be available at Home Depot or Lowe's. You would have to go to a place like Greybar Electric or some other electrical supplier. Terry Neal Next time Pete, just go to a Home Depot or an electrical product supplier and ask for 6/4 SWOO cord. They sell it by the foot. What I used for my new 50 foot shore power cord. Also, Ernie Ekberg is making him one too. It comes in other sizes such as 8/4 10/4 12/4 12/3 etc. Terry Neal Bozeman, MT 82PT40 74FC34 Pete Masterson wrote: > In searching for a 50 amp extension cord for my coach, I see that > some eBay sellers are offering 50 amp cords with three 6 gauge wires > and one 8 gauge wire (presumably the ground wire). This corresponds > to some "50 amp range cords" I've seen in home centers with the same > size wires. > > What is difficult is finding 50 amp Romex in the 6 gauge size. (I > needed a couple of feet of 6 gauge wire to wire in the Progressive > Industries surge protector I got for my coach...) I had to purchase > individual wires (in suitable colors) as the home center did not > carry any such Romex. > > I have had no trouble getting 30 amp (10 gauge) wire for additions to > my home wiring system. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > On Jul 8, 2007, at 6:47 AM, bubblerboy64 wrote: > > > Thanks for the information on this subject. The ONAN is rated at > > 6500 watts not 8500. I would think if all is well it should handle > > the two air conditioners. I'll have to consider the conversion to 50 > > amp service. I was not aware that 6 gauge wire for shore power was > > available. And here I thought 10 gaurge large. JOhn Heckman > > Central Pa > > '73 FC > > > > > > > <snip> > > [Non-text portions of this message have been removed] > > Best Regards, Ron Thompson Waller, Tx. 1995 WLWB 42'Blue Bird Body #F112297 (cockyfox@...) [Non-text portions of this message have been removed] |
07-09-2007, 10:06
30 amp VS 50 amp
Terry Neal provided a new 6-4 cable- pretty flexible to replace my 25 OEM.
Since I am about 45 feet away from the hookup- this will be great. I have been operating with my OEM plus an extension cable. This will eliminate the splice and I will remake the extension cord so that I can use that in marginal situations. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-09-2007, 12:58
30 amp VS 50 amp
Please pardon me for making some confusing statements -- I had two
issues: 1. I needed about 24 to 36 inches of 6 gauge wire to let me wire-in the full-coach surge protector I bought. "House-type" wiring will work fine. The Home Depot I went to appeared to be out of stock on Romex-type 6 gauge 4 conductor wire. We found some single wires "in stock" in 6 gauge with red, white, black, and green insulation. They will do the job. Perhaps other Home Depot (or Lowes) maintain better stock levels. While looking for this cable, I briefly considered getting a replacement "range cord" as an alternative. It probably would have worked, but I note that it had three conductors in 6 gauge with the ground in 8 gauge wire. 2. After a 3 month on the road trip, I realize that I need a relatively short 50 amp shore power _extension_ cord. (I have a 30 amp extension.) At one RV park, I ran into a case where my coach cable couldn't reach the power pedestal, or I'd need a super-long bunch of sewer hose. If I moved too far forward, then the front jacks would be off a flat concrete pad an onto a sloped ramp. After some considerable back and forth and much arm waving by my spouse, I was able to 'fit' so that I could reach all the usual hookups. A couple feet of extension cord would have saved me a lot of maneuvering. Of course, it was in the middle of a thunderstorm at the end of a long day of driving at the time. (It always seem like many RV parks put the power pedestal near the center of the space (and my hook-up is way toward the rear) and the sewer line is way toward the back and mine is closer to the center.... <sigh>.) In a couple of other cases, I had to use extra sewer extensions -- but I'd have preferred to have less slinky hose to clean up in trade off for reaching the power pedestal. I note that Camping World sells a 30' 50amp extension cable with the correct plugs molded on the ends. I probably could get by with only 10 feet ... but I'll probably buy the one at Camping World since it's currently on sale until the end of the month. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 9, 2007, at 2:53 PM, Ron Thompson wrote: > Pete, > > I have bought that 6guage, 4 conductor cable at both Home Depot and > Lowe's. They both had it. However what they have is for interior > wiring and direct burial cable. It is good for running inside your > home from the breaker box to and external 4 way plug. But if your > intention is to run from a shoreline plug to the motorhome you > would want a more flexible cable and that would not be available at > Home Depot or Lowe's. You would have to go to a place like Greybar > Electric or some other electrical supplier. > > > > Terry Neal > wrote: Next time Pete, just go to > a Home Depot or an electrical product > supplier and ask for 6/4 SWOO cord. They sell it by the foot. > What I > used for my new 50 foot shore power cord. Also, Ernie Ekberg is > making > him one too. It comes in other sizes such as 8/4 10/4 12/4 12/3 etc. > > Terry Neal > Bozeman, MT > 82PT40 > 74FC34 > > Pete Masterson wrote: > >> In searching for a 50 amp extension cord for my coach, I see that >> some eBay sellers are offering 50 amp cords with three 6 gauge wires >> and one 8 gauge wire (presumably the ground wire). This corresponds >> to some "50 amp range cords" I've seen in home centers with the same >> size wires. >> >> What is difficult is finding 50 amp Romex in the 6 gauge size. (I >> needed a couple of feet of 6 gauge wire to wire in the Progressive >> Industries surge protector I got for my coach...) I had to purchase >> individual wires (in suitable colors) as the home center did not >> carry any such Romex. >> >> I have had no trouble getting 30 amp (10 gauge) wire for additions to >> my home wiring system. >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> El Sobrante CA >> aeonix1@... >> >> On Jul 8, 2007, at 6:47 AM, bubblerboy64 wrote: >> >>> Thanks for the information on this subject. The ONAN is rated at >>> 6500 watts not 8500. I would think if all is well it should handle >>> the two air conditioners. I'll have to consider the conversion to 50 >>> amp service. I was not aware that 6 gauge wire for shore power was >>> available. And here I thought 10 gaurge large. JOhn Heckman >>> Central Pa >>> '73 FC >>> >>> >>> >> <snip> >> >> [Non-text portions of this message have been removed] >> >> > > > > > > > Best Regards, > Ron Thompson > Waller, Tx. > 1995 WLWB 42'Blue Bird > Body #F112297 > (cockyfox@...) > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
07-10-2007, 07:17
30 amp VS 50 amp
Pete,
On 7/9/07, Pete Masterson > > I note that Camping World sells a 30' 50amp extension cable with the > correct plugs molded on the ends. I probably could get by with only > 10 feet ... but I'll probably buy the one at Camping World since it's > currently on sale until the end of the month. > I bought one of these on eBay - not sure if it was the camping world brand, but it's a 30 foot, 50 amp extension cord with male & female "dryer" outlets molded on. Paid less than $100 including shipping. I don't know how much they want at Camping World but considering how expensive these cord sets seem to be elsewhere, eBay might be worth checking out. I'm very happy with mine. You will appreciate the longer cable. There is no mechanism for keeping water out of that big dryer plug and nobody wants to be dealing with wet, raining conditions and a 50 amp extension cord just laying there, soaking up the water at the joint between the two cords. Seems dangerous as all hell to me. So, when I need to use my extension cord, I connect the two cables then shove that joint way under the bus. This keeps it out of the weather where it will stay nice and dry. So even though I don't need all those 30 extra feet, they come in handy to route the cable under the bus and back. -Ryan |
