Towbar lubrication
07-12-2007, 13:45
Towbar lubrication
I have a Blue Ox towbar to haul my 1995 Jeep Cherokee Sport around.
What is the proper lubrication to use on the pins at the toad end? I
looked on the Blue Ox site, but they seem to avoid that area.
Gardner
78FC33
07-12-2007, 23:23
Towbar lubrication
Gardner:
If you are referring to the steel pins that fasten the bar to your
toad no lubrication is required or wanted. Lube would just pick up
dirt and make a mess.
Bruce
1988 FC35
on our way to Nashville today
07-13-2007, 02:23
Towbar lubrication
We have a Demco, No lube at the tow plate attachment .
I disassembly the tubes and lube the parts with anti-seize, this holds
up for about two years.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> Gardner
> 78FC33
07-13-2007, 05:08
Towbar lubrication
The only thing the owner's manual for my Blue Ox tow bar suggests to
"clean and lubricate" is the extendable arms "once a year." (You need
to remove the rubber boots to perform this task and use nylon
electrical ties to re-attach the boots.) My bar has a spherical joint
(it does not use a ball-hitch) that the manual explicitly says "do
not lubricate."
I did use some light oil on the 'hinges' at the RV end of the arms
because the then new tow bar was so stiff that it was near-impossible
to spread them to change from the storage position to the towing
position.
I have not lubricated the pins that go through the couplings on the
toad end. I will probably use WD-40 or some penetrating oil if the
pop-outs that hold the pins in place should even fail to operate
smoothly. Oil or grease on the pins are likely to simply attract road
dust and other dirt --- making their lubrication probably a negative
instead of a plus.
Pete Masterson, Author of
Book Design and Production: A Guide for Authors and Publishers
Aeonix1@...
Aeonix Publishing Group http://www.aeonix.com
> Gardner
> 78FC33
07-15-2007, 14:30
Towbar lubrication
Bruce, Bill, Pete,
Thanks for your responses. I was thinking that lubrication was not
required, but you have confirmed that for me. I would hate to have let
it go and then found out I shortened the life of my precious ( and not
cheap) Blue Ox towbar.
Gardner
78FC33
around.
> Gardner
> 78FC33
