Help with generator problem, AC voltage
05-10-2005, 04:40
Its very nice to have a frequency meter, but an accurate tach should
also tell you when the frequency is correct. (See Stephen's notes below). If the voltage is wrong when the RPM and frequency are correct, then you are looking for problem that is not related to engine speed. (See notes from Jeff and others about the transfer switch, neutral, and regulator). If you start working with the mechanical governor, remember that the settings are not correct until the engine speed stays constant from no load to full load. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > 1800rpm = 60 cycles on four pole Generator > 3600rpm =60 cylyes on 2 pole generator > any more or less you risk major damage > Cape0001 77fc35 > > > --- In WanderlodgeForum@yahoogroups.com, Byrne Lobdell > > > I would be very careful adjusting the mechanical Governor to get the > voltage up. The mechanical adjustment only changes the RPM of engine > which in turns changes the frequency of the output voltage. Too high > or too low frequency can damage any non resistive load. (Inverters, > TV, Battery Chargers, Microwave, etc.) I am not sure of the Voltage > Regulator you have but most have a way to set voltage. If no voltage > adjustment is on regulator you may need to replace regulator. If you > have done any mechanical adjustment to the engine governor you need to > get a good frequency meter and be sure the frequency is set at 60 cycles. > > Byrne 7735FC > > > > "Hovda, Craig" > > I had low voltage on my 90WL40 and I adjusted the idle and it brought up > > the voltage to the proper level. > > > > > > > > Craig > > > > 40WL > > > > Bigfork Mt. > > > > > > > > ________________________________ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jeff Miller > > Sent: Friday, May 06, 2005 8:26 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Help with generator problem, AC voltage > > > > > > > > You have an open neutral somewhere between the genset and load center. > > Try cycling the transfer switch first. > > > > - Jeff Miller > > http://www.wanderlodge.net > > http://www.millercoachworks.com > > > > > > --- In WanderlodgeForum@yahoogroups.com, "awojteczko" wrote: > > > Hello, > > > > > > I wonder if I can get some help with my generator problem? > > > The generator runs well but my AC voltages are 112 and 147 volts ac > > on > > > legs one and two. When I plug in a vacuum cleaner it will barely turn > > > the motor. If I turn the hot water heater on the relay under the sink > > > chatters like crazy. Could this be a brush problem in the generator? > > > If anyone has had a similar problem and could point me in the right > > > direction it would be very much appreciated. > > > > > > Thanks, > > > Andy > > > 88WB40 > > > Caledon East, Ontario, Canada > > > > > > > > > > > > ________________________________ > > > > Yahoo! Groups Links > > > > * To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/> . > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > --------------------------------- > > Yahoo! Groups Links > > > > To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > --------------------------------- > > Yahoo! Mail Mobile > > Take Yahoo! Mail with you! Check email on your mobile phone. > > > > [Non-text portions of this message have been removed] |
