2005 450 LXI
12-02-2007, 05:15
2005 450 LXI
Jon, lots of the newer coaches are total electric.
Ernie Ekberg 83PT40 Weatherford, Tx with house type refer **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed] |
12-02-2007, 08:15
2005 450 LXI
Was I reading that article right? Do these newer Wanderlodge not
have three way refrigerators? You know 110AC ,12volt and propane? I would think that at around 450,000 dollars they would have this set up. And why at this price do they not have on top solar battery charger? Guess sometimes older is better. Jon |
12-02-2007, 13:16
2005 450 LXI
> > Jon, lots of the newer coaches are total electric. > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > with house type refer Is there any particular reason for this? Seems that maybe these newer rigs are more for non-dry camping. But I guess it would cost the coach company a few more bucks to install a propane system or one of those diesel heating systems. I was wondering if they have an exhaust system that might rise up like a periscope to exhaust all those smelly exhaust fumes you get when your running your generator. I kind of wander what the air quality must be like at a place like Quartzite Arizona when you have 100's of motor homes running there generators at the same time. Phew maybe one should bring an extra oxygen pack to get some fresh air. Jon > > > > **************************************Check out AOL's list of 2007's hottest > products. > (http://money.aol.com/special/hot-products-2007? NCID=aoltop00030000000001) > > > [Non-text portions of this message have been removed] > |
12-02-2007, 14:23
2005 450 LXI
The newest Blue Birds use a _lot_ of electricity. You'd probably need
the roof space of 3 or 4 birds to have sufficient solar power to really make a dent in the electrical draw. (The newest birds have a 20KW generator.) I'm not sure when the first "all electric" Birds were made, but my '95 is all electric and has a standard home-style 22 or 24 cu ft. Amana two door refrigerator. It operates only on 120 vac only. I also have a 120 vac cook top. (It doesn't heat up as fast as a 220 vac unit would, but it seems like it gets as hot as any other electric stove I've used with similar sized "burners" -- in other words, it's better than a hot plate.) The two 2500 watt inverters supply power to the microwave and refrigerator as well as several of the wall plugs and 120 vac light fixtures. I've never tried the convection oven feature while on inverter power, but I'd guess it's "on" as well. The cooktop is not powered by the inverters. I'll observe that the all-electric is a blessing and a curse. The blessing is that I never have to deal with getting propane, worry about lp gas connections or adjustments, nor worry about an aging lp gas tank. The curse is that the home-type refrigerator really sucks the house batteries down fast. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lubbock Texas On Dec 2, 2007, at 2:15 PM, Jon wrote: > Was I reading that article right? Do these newer Wanderlodge not > have three way refrigerators? You know 110AC ,12volt and propane? I > would think that at around 450,000 dollars they would have this set > up. > > And why at this price do they not have on top solar battery charger? |
12-02-2007, 14:29
2005 450 LXI
Choice of all-electric and home-style refrigerator in a BB is
probably not economic (money saving in manufacture) but is probably a convenience issue. My '95 has a cap for the ground level genny exhaust, when screwed on, the generator fumes are directed out through a roof-top exhaust pipe. There is no 'switching' involved other than plugging the lower exhaust pipe outlet. Exhaust gasses apparently prefer the path of least resistance. Since BB tends to keep features that work, I suspect that this remains on later models. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lubbock Texas On Dec 2, 2007, at 7:16 PM, Jon wrote: > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: >> >> Jon, lots of the newer coaches are total electric. >> >> Ernie Ekberg >> 83PT40 >> Weatherford, Tx >> >> with house type refer > > Is there any particular reason for this? Seems that maybe these newer > rigs are more for non-dry camping. But I guess it would cost the > coach company a few more bucks to install a propane system or one of > those diesel heating systems. > > I was wondering if they have an exhaust system that might rise up > like a periscope to exhaust all those smelly exhaust fumes you get > when your running your generator. |
12-02-2007, 14:31
2005 450 LXI
I carry 100 gallons of LPG to run my frig, stove top, and outdoor
grill. The more ways to make power, the merrier... Another downside of carrying LPG is the space it takes. I'd have a second pass-through bay if I ditched the propane tank. David Brady '02 LXi, Ca --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > The newest Blue Birds use a _lot_ of electricity. You'd probably need > the roof space of 3 or 4 birds to have sufficient solar power to > really make a dent in the electrical draw. (The newest birds have a > 20KW generator.) > > I'm not sure when the first "all electric" Birds were made, but my > '95 is all electric and has a standard home-style 22 or 24 cu ft. > Amana two door refrigerator. It operates only on 120 vac only. I also > have a 120 vac cook top. (It doesn't heat up as fast as a 220 vac > unit would, but it seems like it gets as hot as any other electric > stove I've used with similar sized "burners" -- in other words, it's > better than a hot plate.) > > The two 2500 watt inverters supply power to the microwave and > refrigerator as well as several of the wall plugs and 120 vac light > fixtures. I've never tried the convection oven feature while on > inverter power, but I'd guess it's "on" as well. The cooktop is not > powered by the inverters. > > I'll observe that the all-electric is a blessing and a curse. The > blessing is that I never have to deal with getting propane, worry > about lp gas connections or adjustments, nor worry about an aging lp > gas tank. The curse is that the home-type refrigerator really sucks > the house batteries down fast. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Lubbock Texas > > > > On Dec 2, 2007, at 2:15 PM, Jon wrote: > > > Was I reading that article right? Do these newer Wanderlodge not > > have three way refrigerators? You know 110AC ,12volt and propane? I > > would think that at around 450,000 dollars they would have this set > > up. > > > > And why at this price do they not have on top solar battery charger? > |
12-03-2007, 03:16
2005 450 LXI
Jon, about Quartzsite, last year was my fist experience and I think it
was probably more like 1,000s of generators running. There seem to be a nice breeze going every day; it was awesome, warm in the sun, cool in the shade, just right at night. One thing that puzzles me, with all the solar panels collecting all that solar energy, it was still warm ![]() Marty Gregg 97 BMC 37 Kennewick WA. |
12-03-2007, 05:08
2005 450 LXI
Dave, We may have the best of both worlds..an lp ref and nothing else..although
I had to have mine serviced this year. Aqua hot works great. We still ran the generator 30 minutes to an hour twice a day when dry-camping at Branson over Thanksgiving. It was pretty cold at night. The engine preheat worked great too. I'm not sure about the generator engine pre-heat. It appears to be just electric. If so, why would you want to preheat the generator when you're already on the grid, or why use preheat when you have glow-plugs..or..does Aqua hot pump warmed water to the generator?Brad Barton 00LXiDFWbbartonwx@... To: WanderlodgeForum@...: aeonix1@...: Sun, 2 Dec 2007 20:23:33 -0600Subject: Re: [WanderlodgeForum] 2005 450 LXI The newest Blue Birds use a _lot_ of electricity. You'd probably need the roof space of 3 or 4 birds to have sufficient solar power to really make a dent in the electrical draw. (The newest birds have a 20KW generator.)I'm not sure when the first "all electric" Birds were made, but my '95 is all electric and has a standard home-style 22 or 24 cu ft. Amana two door refrigerator. It operates only on 120 vac only. I also have a 120 vac cook top. (It doesn't heat up as fast as a 220 vac unit would, but it seems like it gets as hot as any other electric stove I've used with similar sized "burners" -- in other words, it's better than a hot plate.)The two 2500 watt inverters supply power to the microwave and refrigerator as well as several of the wall plugs and 120 vac light fixtures. I've never tried the convection oven feature while on inverter power, but I'd guess it's "on" as well. The cooktop is not powered by the inverters.I'll observe that the all-electric is a blessing and a curse. The blessing is that I never have to deal with getting propane, worry about lp gas connections or adjustments, nor worry about an aging lp gas tank. The curse is that the home-type refrigerator really sucks the house batteries down fast.Pete Masterson'95 Blue Bird Wanderlodge WBDA 42aeonix1@... the road at Lubbock TexasOn Dec 2, 2007, at 2:15 PM, Jon wrote:> Was I reading that article right? Do these newer Wanderlodge not> have three way refrigerators? You know 110AC ,12volt and propane? I> would think that at around 450,000 dollars they would have this set> up.>> And why at this price do they not have on top solar battery charger? _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/connect.html?...ays_112007 [Non-text portions of this message have been removed] |
