King Pin Lube Spec
05-11-2005, 07:39
King Pin Lube Spec
It just amazes me what new material we keep learning from our members. Thats
what makes a great forum. Thank you all very much. Ernie-83PT40 in Texas [Non-text portions of this message have been removed] |
05-11-2005, 11:19
King Pin Lube Spec
Contrary to what we all thought to be correct, a member has sent in
the BB king pin lube spec from a 1983 blue box owner's manual. The two pages have been loaded to a file for review. It seems to contradict what was frequently discussed on the old forum and accepted as fact; namely that you are supposed to lube the king pins with the wheels off the ground. This documentation clearly says not to raise the wheels off the ground. Has there been an update bulletin from Rockwell since 1983 reversing the procedure? Very interesting. Mike Bulriss 83 PT40 "Stagecoach" - for sale 91 PT40 "Texas Minivan" San Antonio, TX |
05-11-2005, 12:27
King Pin Lube Spec
Cynic that I am I submit a lawsuit resulted in the reversal of technique.
Somebody dropped something, and it wasn't good. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: mbulriss To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 11, 2005 6:19 PM Subject: [WanderlodgeForum] King Pin Lube Spec Contrary to what we all thought to be correct, a member has sent in the BB king pin lube spec from a 1983 blue box owner's manual. The two pages have been loaded to a file for review. It seems to contradict what was frequently discussed on the old forum and accepted as fact; namely that you are supposed to lube the king pins with the wheels off the ground. This documentation clearly says not to raise the wheels off the ground. Has there been an update bulletin from Rockwell since 1983 reversing the procedure? Very interesting. Mike Bulriss 83 PT40 "Stagecoach" - for sale 91 PT40 "Texas Minivan" San Antonio, TX ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-12-2005, 05:27
King Pin Lube Spec
Mike what do you think about lubing the kingpins? I was always told to take
the load off before greasing so the entire pin would get lube around it. I have the factory manual in my coach and will bring it home later today. I just lifted the wheel that I was lubing slightly off the ground with my 22 1/1 ton air/hydraulic floor jack. Interesting. Tom 1982 FC35 Vernon Center,NY At 07:27 PM 5/11/2005 -0500, you wrote: >Cynic that I am I submit a lawsuit resulted in the reversal of >technique. Somebody dropped something, and it wasn't good. >Mike Hohnstein >Germantown, WI >83FC35 > ----- Original Message ----- > From: mbulriss > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 11, 2005 6:19 PM > Subject: [WanderlodgeForum] King Pin Lube Spec > > > Contrary to what we all thought to be correct, a member has sent in > the BB king pin lube spec from a 1983 blue box owner's manual. The > two pages have been loaded to a file for review. It seems to > contradict what was frequently discussed on the old forum and accepted > as fact; namely that you are supposed to lube the king pins with the > wheels off the ground. This documentation clearly says not to raise > the wheels off the ground. Has there been an update bulletin from > Rockwell since 1983 reversing the procedure? Very interesting. > > Mike Bulriss > 83 PT40 "Stagecoach" - for sale > 91 PT40 "Texas Minivan" > San Antonio, TX |
