What to Use to Remove Faint Scratches from Bay Door?
11-04-2007, 12:14
Howdy.
Liz discovered 2 faint parallel scratches on one of the bay doors. The scratches are about 14 inches long but they are not very deep. The coach is dark teal and these scratches are light teal. What can I use to buff out these scratches? TIA, Jack Jack and Liz Pearce 1993 Wanderlodge Aledo, TX |
11-04-2007, 12:38
Suggestions...
Could be the lighter color is what transferred to your coach. Start with wax intended for automotive paint. Put a small amount of wax on a wax pad or terry towel and rub a very small area first. If that gets rid of the lighter color, great. The scratch will still be there but less noticeable when the lighter color has been removed. Next, maybe, a very fine rubbing compound followed by the wax. Experiment in a small area fir st. If that doesn't work, contact an automotive detail mobile person and ask if they can remove scratches. On 11/4/07, Jack and Liz Pearce > > Howdy. > Liz discovered 2 faint parallel scratches on one of the bay doors. The > scratches are about 14 inches long but they are not very deep. The > coach is dark teal and these scratches are light teal. What can I use to > buff out these scratches? > > TIA, > Jack > Jack and Liz Pearce > 1993 Wanderlodge > Aledo, TX > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-04-2007, 12:50
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> > Suggestions... > Could be the lighter color is what transferred to your coach. Start with wax > intended for automotive paint. Put a small amount of wax on a wax pad or > terry towel and rub a very small area first. If that gets rid of the lighter > color, great. The scratch will still be there but less noticeable when the > lighter color has been removed. > > Next, maybe, a very fine rubbing compound followed by the wax. Experiment in > a small area fir > st. If that doesn't work, contact an automotive detail mobile person and ask > if they can remove scratches. > > On 11/4/07, Jack and Liz Pearce > > > > Howdy. > > Liz discovered 2 faint parallel scratches on one of the bay doors. The > > scratches are about 14 inches long but they are not very deep. The > > coach is dark teal and these scratches are light teal. What can I use to > > buff out these scratches? > > > > TIA, > > Jack > > Jack and Liz Pearce > > 1993 Wanderlodge > > Aledo, TX > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] What color is this area? I use a polish put out by Turtle Wax that has a paint pigment added and it really works great. The container has a special marking pen attached to the product that has the same color as the Wax and it also works very well using the liquid wax. Very easy to use and looks pretty good after the application. By the way my color is Black and that really shows scratches. Jon Rebel Bird Bremerton Washington > |
11-05-2007, 12:58
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> > Howdy. > Liz discovered 2 faint parallel scratches on one of the bay doors. The > scratches are about 14 inches long but they are not very deep. The > coach is dark teal and these scratches are light teal. What can I use to > buff out these scratches? > > TIA, > Jack > Jack and Liz Pearce > 1993 Wanderlodge > Aledo, TX > Howdy. A big THANK YOU to all that replied to my message. I have some Meguiar's ScratchX that I will try. I"ll let you know what happens. Thanks again, Jack Jack and Liz Pearce 1993 Wanderlodge Fulltimers [Non-text portions of this message have been removed] |
