Gen has stop making electricity
11-12-2007, 04:46
Scott, do you have the manual or automatic change over switch?
83PT40
************************************** See what's new at http://www.aol.com
11-12-2007, 08:25
My Kohler generator has stopped making juice. Engine part is fine.
Ideas to troubleshoot?
Scott Forman
86 PT38
Memphis
11-12-2007, 08:33
Scott,
You made sure that the breakers on the generator are not tripped?
Al Johnson
'96 BMC B75 ==> B100
Mandeville, Louisiana
> Scott Forman
> 86 PT38
> Memphis
11-12-2007, 09:43
Yes
--- In WanderlodgeForum@yahoogroups.com, "Al" wrote:
> Scott,
tripped?
> Al Johnson
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
fine.
> > Scott Forman
> > 86 PT38
> > Memphis
11-12-2007, 15:31
Manual
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
http://www.aol.com
11-12-2007, 15:37
Scott, it is fairly easy to inspect the brushes and leads so have you
checked them to see if they are good?
Dan
88pt38
Jackson, MS
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman
Sent: Monday, November 12, 2007 9:32 PM
Subject: [WanderlodgeForum] Re: Gen has stop making electricity
Manual
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
http://www.aol. <http://www.aol.com> com
11-13-2007, 17:26
Yup. Check those brushes. If they're good, check the voltage regulator next.
-Ryan
'86 PT-40 8V92
> Dan
> 88pt38
> Jackson, MS
11-14-2007, 02:13
regulator next.
> -Ryan
> '86 PT-40 8V92
you
> > Dan
> > 88pt38
> > Jackson, MS
If it is a transformer regulated generator then check the taps on the
transformer. Mine started making 80 volts instead of 120. After
much searching i grabbed the wires and shook one loose from the sapde
connector. Fixed that and was back in business at 120 volts.
Bob Criss
90SP36
Bethel Park, PA
11-14-2007, 11:32
It's down at the shop now, same guys who rebuilt the Kohler in my 82
FC (I knew it was bad when I bought the coach). I am sure they will
find it, I just hope it isn't the same problem that killed the other
one.
Scott
regulator next.
> -Ryan
> '86 PT-40 8V92
you
> > Dan
> > 88pt38
> > Jackson, MS
