Inverter Thoughts - (was BOW)
01-04-2008, 18:03
Another repost to get the subject going on inverters....hopefully
this is helpful
Mike,
Interesting thought. Did you try to re-arrange any of the loads
to "restrict" what can run off the inverter?
I was thinking about putting in a sub-panel so I don't have to worry
about the kids turning things on that would not be desirabe for an
inverter (heater or A/C). I can see when I'm not around and they
react, flip a switch...yes it is working so it must be ok....not good
for my crew. Using a sub-panel would make it kid proof.
So far, I'm thinking about the Microwave, receptacles in the Kitchen,
dining, bedroom, and front, and the icemaker.
My readi-line is still working for the Kitchen and ice-maker. But, I
do not like the battery chargers and the limited inverter outlets.
Did you install into the redi-line / charger compartment? Have you
had a problem in wet weather?
Thanks,
Glenn Allen
1986 PT-40
Marietta, GA
<MHOHNSTEIN@...> wrote:
> Reassign one of the 30a shore receptacles to the inverter, that's
what I did, simple and works real well. You never use those any way.
> Mike Hohnstein
> Germantown, WI
> 83FC35
01-05-2008, 03:07
Depends how detailed one wants to get. Selected leg that was more appropriate
for the galley, added a box to join the inverter supply to 30a leg.
Leave inverter on most of the time. Solar panels, 2500 heart inverter/charger 4
Concord life lines for house service, one Optima for gen set, single truck
service chassis batt with batt combiner @ key on.
System is good for overnight most of the time, the new flat screen seems to suck
a lot of power.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Saturday, January 05, 2008 12:03 AM
Subject: [WanderlodgeForum] Inverter Thoughts - (was BOW)
this is helpful
Mike,
Thanks,
Glenn Allen
1986 PT-40
Marietta, GA
> Mike Hohnstein
> Germantown, WI
> 83FC35
01-05-2008, 03:50
Is that flat-screen plasma or LCD?
Dorn Hetzel
77FC35
Hogansville, GA
> appropriate for the galley, added a box to join the inverter supply to 30a
> leg.
> inverter/charger 4 Concord life lines for house service, one Optima for gen
> set, single truck service chassis batt with batt combiner @ key on.
> to suck a lot of power.
> Mike Hohnstein
> Germantown, WI
> 83FC35
> From: Glenn Allen
> this is helpful
> Mike,
> Thanks,
> Glenn Allen
> 1986 PT-40
> Marietta, GA
> "Mike Hohnstein"
> > Mike Hohnstein
> > Germantown, WI
> > 83FC35
01-05-2008, 03:59
Damned if I know. Use it for the 'puter moniter so I can read.
MH
Sent: Saturday, January 05, 2008 9:50 AM
Subject: Re: [WanderlodgeForum] Inverter Thoughts - (was BOW)
Dorn Hetzel
77FC35
Hogansville, GA
> leg.
> Mike Hohnstein
> Germantown, WI
> 83FC35
> From: Glenn Allen
> this is helpful
> Mike,
> Thanks,
> Glenn Allen
> 1986 PT-40
> Marietta, GA
> "Mike Hohnstein"
> > Mike Hohnstein
> > Germantown, WI
> > 83FC35
