Water pressure regulator/tank fill valve mystery solved
03-21-2008, 15:24
On our recent visit with Ralph and Charolette in our 89FC35, Ralph and
I performed the obligatory 'walk around' of our coach. I opened the
utility hookup door, (street side rear) and Ralph immediately spotted
the non standard piece of garden hose added by a PO. Ralph's comment
was "get rid of that" as I tried to explain I was not the guilty party
responsible for this re-engineered method for filling the pure water
tank via a 1/2" hose protruding through a 1" hole bored through the
backside steel bulkhead of the utility compartment.
Now settled down after our South Texas travels, I'm doing preventive
maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, new D2
air governor.
We've had this 35FC 18 months now and that dangling piece of fill hose
has bugged us long enough...previous owner told me that's the only way
to fill the fresh water tank. Turns out, the first night we spent in
the coach when bringing it home from GA, the regulator /fill valve
leaked like a sieve (through the 2 small holes where you insert snap
ring pliers for service) and the first repair I made to the coach 18
mos ago was replacing that regulator assembly. This fixed the leak.
Previous owner related he did not ever hook to 'city water' but in lieu
always filled the tank through this stupid hose and like a dummy I've
continued to use the "hose thru the wall" instead of filling by
flipping the fill switch to energize the sporlan valve. Hose is gone
now and I plugged the hole with a chrome plug purchased at Lowe's.
My lesson here is simple; try to keep the original systems fully
operational when practical! This case of the water hose added to
bypass the factory regulator could have been avoided by merely doing
the preventive maintenance on the regulator and the city water function
as well as the electric fill function could have remained intact.
Ralph, thanks for helping us keep the Blue Bird systems working; also
thanks to all who contribute to the forum.
Dick Gideon
Freedom Bird
1989 35FC
Rolla, MO
03-21-2008, 17:38
The mystery is why was the garden hose installed?
The potable water tank fill is an appliance on the citywaterhookup
line. like an icemaker or sink. On 91 and newer birds the sporlan
is a diaphram valve like a automatic lawn sprinkler valve. the valve
is closed passivly then opened when the valve is energized by the
switch. the problem with the notion that it is closed all the time
is that when there is no pressure pushing into the input side of the
sporlan tankfill valve, the diaphram that keeps the valve closed
floats open. since ther is no pressure, water doesnt pass but air
gets in the valve.
when the plumbing system in the bus is not hooked to city water and
the automatic 12 volt pump is turned off, some one is sure to open a
sink valve and depressurize the plumbing lines which will float the
valve open. when this happens and the bus sits for a month or two,
scum builds up on the rubber and the valve will not shut closed. if
the valve does not shut closed, hooking up to city water the potable
tank will overfill. with the valve failed open, running on the
12volt pump you will keep removing water from the tank and refill
the tank with that water so removed.
Fulltimers have frequent or constant pressure up against the valve
thus have not this problem but us monthly or bimonthly users
welcome your "hose through the wall upgrade"
One caution I see with filling the potable tank too fast via a non
Bird-engeneered design is if you fill it faster than the air or over
fill pipe can exhaust the air or water you build pressure in
the 'not designed to be pressurized', plastic tank. This may cause
the potable tank to split. talk about wetting the bed!
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Richard Gideon"
spotted
comment
party
water
preventive
D2
> air governor.
hose
way
in
snap
18
leak.
lieu
I've
gone
doing
function
also
> Dick Gideon
> Freedom Bird
> 1989 35FC
> Rolla, MO
03-22-2008, 01:41
Greg: All good points; the sporland is working just fine; my guess
is that the PO installed the bypass hose setup simply because the
check valve within the external water fill/regulator needed a good
cleaning...I chose to replace the water fill/regulator because of my
lack of knowledge for disassembly for service. Just adding my 2
cents regarding "quick fixes" to solve a problem and thereby possibly
introducing a new problem or inconvenience. Kinda like some of those
temporary fences I used to build on our farm years ago...many of them
are still being used!
Dick Gideon
Freedom Bird
1989 35FC
Rolla, MO
valve
> gets in the valve.
a
potable
over
cause
> GregoryO'Connor
> 94ptRomolandCa
Ralph
> and
> the
> spotted
> comment
> party
> water
> the
> preventive
> D2
> > air governor.
> hose
only
> way
spent
> in
valve
> snap
> 18
> leak.
in
> lieu
> I've
> gone
> doing
> function
> also
> > Dick Gideon
> > Freedom Bird
> > 1989 35FC
> > Rolla, MO
03-22-2008, 04:38
Dick, Farmers across the country had a crisis when nylon string
replaced bailing wire in hay packaging. I found a professional
bailing wire device at Quartsite 07 and returned this year to buy it
because my 07 statement "I can make one of these" never put metal to
mill. I was disapointed when the vender didnot show up this year.
Forum member, Dick Hayden found one of the tools earlier this month
and sent it to me in the mail. This is a got to have tool for
everyone. I will find a web site or take pics and post soon. A big
thank to DickH for my much loved ClampTool
GregoryO'Connor
94ptRomolandCa
guess
my
possibly
those
them
> Dick Gideon
> Freedom Bird
> 1989 35FC
> Rolla, MO
citywaterhookup
sporlan
> valve
time
> the
closed
air
> > gets in the valve.
> and
open
> a
two,
if
> potable
refill
valve
non
> over
> cause
> > GregoryO'Connor
> > 94ptRomolandCa
> Ralph
> > and
opened
> > the
> > spotted
> > comment
guilty
> > party
> > water
through
> > the
> > preventive
new
> > D2
> > > air governor.
fill
> > hose
> only
> > way
> spent
> > in
> valve
insert
> > snap
coach
> > 18
> > leak.
but
> in
> > lieu
dummy
> > I've
by
is
> > gone
Lowe's.
fully
to
> > doing
> > function
intact.
working;
> > also
> > > Dick Gideon
> > > Freedom Bird
> > > 1989 35FC
> > > Rolla, MO
03-22-2008, 16:34
Hi All
I had a problem filling the water.I fulltime and needed water so I
disconnected the overfill above the tank and filled the water with a
hose. Did not make any permanent modification .Started to look for a
fix.Was advised to clean and lubricate the pressure regulator fill
valve sounded difficult turned out to be very easy ( thanks Ralph )
Nothing modifed still original and works great.
Mario 1985FC35 in MV MA. Coach in SoCal
it
to
month
big
> GregoryO'Connor
> 94ptRomolandCa
> guess
good
of
> my
> possibly
> those
> them
> > Dick Gideon
> > Freedom Bird
> > 1989 35FC
> > Rolla, MO
> citywaterhookup
> sporlan
> > valve
> the
> time
of
> > the
> closed
> air
> > > gets in the valve.
water
> > and
> open
> > a
float
> the
> two,
closed.
> if
> > potable
> refill
> valve
> non
or
> > over
> > cause
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > Ralph
> > > and
> opened
> > > the
immediately
> > > spotted
Ralph's
> > > comment
> guilty
> > > party
pure
> > > water
> through
> > > the
> > > preventive
rebuild,
> new
> > > D2
> > > > air governor.
> fill
> > > hose
> > only
> > > way
> > spent
> > > in
> > valve
> insert
> > > snap
> coach
> > > 18
> > > leak.
> but
> > in
> > > lieu
> dummy
> > > I've
> by
Hose
> is
> > > gone
> Lowe's.
> fully
added
> to
merely
> > > doing
water
> > > function
> intact.
> working;
> > > also
> > > > Dick Gideon
> > > > Freedom Bird
> > > > 1989 35FC
> > > > Rolla, MO
