still trying to fix the engine air conditioner
05-23-2005, 06:46
On EBAY today its somewhere around $265 for 30# (7974763090) . I think
that is still to high. Glad I bought 2 cases of it for $18/case in February
2005 at Sams Club. Have you checked there?
Tom
1982 FC35
Vernon Center,NY
At 10:12 AM 5/23/2005 -0700, you wrote:
>In the FWIW department, When I went to recharge my dash air, I found
>my "half full" 30 pounder to be empty. So I stopped by to get a new
>one this morning. Talk about sticker shock!!!! The price is now
>$408!!! Last year I paid around $70 for the same thing. The manager
>said that there had been a shortage of 134a lately and that the price
>was "all over the place". Might be a good reason to use the roof airs
>only.
>George Lowry
>'95 WBDA 4203 & GM 4106 (for sale)
>Spearfish, SD
>Jeff Miller wrote:
> > .. unless the compressor is seized, in which case you'll fairly
> > quickly see smoke from the clutch.
> > - Jeff Miller
> > --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
> > wrote:
> >>Dan: With everything off, disconnect the wire from the compressor &
> >>jumper it directly to the Battery. The clutch should engage(Click).
> >>If the clutch is engaged and the pulley turns with the engine running.
> >>the compressor HAS to turn!!
> >>Jack Smith
> >>1973 A\Cless FC31
> >>Sunny SoCal
> > Yahoo! Groups Links
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
05-23-2005, 06:51
George a little farther down the EBAY page there is 7975803246 , two 30#
cylinders and its only up to $305.
Tom
>only.
>George Lowry
>Spearfish, SD
> > - Jeff Miller
> >>Jack Smith
> >>1973 A\Cless FC31
> >>Sunny SoCal
> > Yahoo! Groups Links
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
05-23-2005, 08:42
Just came back from there... My SIL is a member and I got a 30
pounder for $250.27 including tax. Still ridiculous increase from
last year....
George
> Tom
> 1982 FC35
> Vernon Center,NY
>>only.
>>George Lowry
>>Spearfish, SD
>>> - Jeff Miller
>>>>Jack Smith
>>>>1973 A\Cless FC31
>>>>Sunny SoCal
>>>Yahoo! Groups Links
>>Yahoo! Groups Links
>><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group\
/WanderlodgeForum/
>>Wande\
rlodgeForum-unsubscribe@yahoogroups.com
> Yahoo! Groups Links
05-23-2005, 10:55
--- In WanderlodgeForum@yahoogroups.com, "Dan Saari"
> I will do that in the morning.........thanks ...DAN
> Randy.......I checked today with a mirror and sure enough the
compressor is NOT turning.....Is that a fuze and if so do you know
where its located?????......
> > > > > 1992 WLWB 40ft.
> > > > > Depere, Wi.
> > > > > dans123@a...
> > > Yahoo! Groups Links
> > > a.. To visit your group on the web, go to:
> > > b.. To unsubscribe from this group, send an email to:
> > > WanderlodgeForum-unsubscribe@yahoogroups.com
> > > c.. Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of
> > Service.
> > > [Non-text portions of this message have been removed]
> > Yahoo! Groups Links
> > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> Service.
05-23-2005, 11:47
yep! what jeff said! randydupree93wb
Sent: Monday, May 23, 2005 12:36 PM
Subject: [WanderlodgeForum] Re: still trying to fix the engine air conditioner
... unless the compressor is seized, in which case you'll fairly
- Jeff Miller
> Jack Smith
> 1973 A\Cless FC31
> Sunny SoCal
Yahoo! Groups Links
05-23-2005, 12:00
fuse,or relay.but i don't know where its located! with the engine not
running,with the key on,the ac switchs on,check the wire at the compresssor for
power (with a test light),then check for power at the low pressure switch
located on the freon line at the compressor..randydupree93wb
Sent: Monday, May 23, 2005 6:55 PM
> > > > > 1992 WLWB 40ft.
> > > > > Depere, Wi.
> > > > > dans123@a...
> > > Yahoo! Groups Links
> Terms of
> > Service.
> > Yahoo! Groups Links
of
> Service.
Yahoo! Groups Links
05-23-2005, 13:03
I can speak to that..... I went to charge the system and the
compressor was not engaging. (Always do the simple things first???)
There was a gadget that looked like an inline fuse but when taken
apart, seems more like a fancy connector. Anyway, checked for voltage
and had voltage to that point. Checked continuity from that point thru
the clutch coil and it read infinite... Ran a jumper direct from the
battery to the clutch wire and no engagement. Going tomorrow to pick
up a new clutch - quoted $121. Hopefully I will then have a
completely functioning dash air.
George Lowry
Spearfish, SD
> not running,with the key on,the ac switchs on,check the wire at the
> compresssor for power (with a test light),then check for power at
> the low pressure switch located on the freon line at the
> compressor..randydupree93wb ----- Original Message ----- From: Dan
> Saari To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 23,
> 2005 6:55 PM Subject: [WanderlodgeForum] Re: still trying to fix
>>>>>> 1992 WLWB 40ft. Depere, Wi. dans123@a...
>>>> Yahoo! Groups Links
>> Terms of
>>> Service.
>>> Yahoo! Groups Links
> of
>> Service.
> Yahoo! Groups Links
> Service.
> ------------------------ Yahoo! Groups Sponsor
> --------------------~--> Has someone you know been affected by
> illness or disease? Network for Good is THE place to support health
> awareness efforts!
> http://us.click.yahoo.com/0xaSZB/UOnJAA/.../pkiolB/TM
> Yahoo! Groups Links
