Road help - sump dump and gen door lock lights on
09-21-2008, 16:59
While negotiating a service station apron to get some $3.63 diesel, we
had a minor "scrapping". No major "thump" just a light "screeeee". It appears we dragged the lock bar for the generator slide. Fiddled with the lock lever a bit and then the light came on never to go off again. It also appears we're running low in the right rear. The best inspection we can do with the bus down in the rear doesn't seem to show anything serious, just a light scratching. Any thoughts? Reards, Hippieforever and GPSGary |
09-22-2008, 14:38
Gold star for Ralph F. Private email with good diags on both topics.
The right "butt drag" was a dead load leveler valve. Interestingly enough it probably was failing for a while because we had a pull to the right that has disappeared with the new rear load leveler. Butler Cat is all over the Wy, MT, ND, SD area. Good service not too bad on price. 75 gals of diesel for diags and the $70 part. Let the adventure continue. H4E & GPSGary |
