ZF ECU on Ebay
10-09-2008, 10:18
ZF ECU on Ebay | |||
10-11-2008, 04:01
ZF ECU on Ebay
This is not the ZF electronic control module.
It is a box with 7 or 8 relays, that manages power to the ZF circuits, cruise, indicator lights, high idle etc. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > If I had a zf transmission found in the 300hp Cat 3208 I would pick this > up > > ZF on Ebay > > > <http://cgi.ebay.com/ebaymotors/ZF-5HP-50...ion-Relay- Module-Bl\ > ueBird-Wanderlo_W0QQitemZ200261696115QQcmdZViewItem? hash=item20026169611\ > 5&_trkparms=72%3A727%7C39%3A1%7C66%3A2%7C65%3A12%7C240% 3A1318&_trksid=p3\ > 911.c0.m14> Greg94Ca > |
10-14-2008, 15:01
ZF ECU on Ebay
Bill,
Then is the bid price worth $89.00? Or can you change out relays as needed? The auction ends on Wed. eve. Dan Leftwich Somers NY 1987 35FCSB 300HP ZF 5SPD Trani --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > > This is not the ZF electronic control module. > > It is a box with 7 or 8 relays, that manages power to the ZF > circuits, cruise, indicator lights, high idle etc. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > If I had a zf transmission found in the 300hp Cat 3208 I would pick > this > > up > > > > ZF on Ebay > > > > > > <http://cgi.ebay.com/ebaymotors/ZF-5HP-50...ion-Relay- > Module-Bl\ > > ueBird-Wanderlo_W0QQitemZ200261696115QQcmdZViewItem? > hash=item20026169611\ > > 5&_trkparms=72%3A727%7C39%3A1%7C66%3A2%7C65%3A12%7C240% > 3A1318&_trksid=p3\ > > 911.c0.m14> Greg94Ca > > > |
