Dry camping - battery usage - very simple question
12-06-2008, 06:24
I'm still struggling with trying to figure out if my batteries are
trashed or somehow I have an inordinately high current drain. The facts; 4 - 12volt - 85ah marine deep cycle batteries in parallel Batteries have been fully charged w/ external charger to 14.5+volts current drain with almost everything off (sleep condition) = 6amps measured with a good quality clamp ammeter Question How long should healthy batteries be able to maintain cranking voltage? Regards, GPSGary |
12-06-2008, 07:13
some solenoids are used to maintain conductivity while energised,
some at rest . a 'continious duty solenoid' constantly uses amps to stay open. if the noid is screwed, it is a bigger amp draw then it was 25 years ago. positive lead should come off first battery and negitive off the last battery in a group. you can use a good quality multi meter to find a positive charge in a frame to prove a ground short. clamp the negitive battery with a good jumper cable and poke around at the frame with a meter between the other end of the cable and frame. a digital thermo gun will help find amp loss also. look for heat relitive to surrounding temps. GregO'Connor Tim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > > I'm still struggling with trying to figure out if my batteries are > trashed or somehow I have an inordinately high current drain. > > The facts; > 4 - 12volt - 85ah marine deep cycle batteries in parallel > Batteries have been fully charged w/ external charger to 14.5+volts > current drain with almost everything off (sleep condition) = 6amps > measured with a good quality clamp ammeter > > Question > How long should healthy batteries be able to maintain cranking voltage? > > Regards, > GPSGary > |
12-06-2008, 07:30
Gary,
You are charging the batteries at too high a voltage. 13.8-14.2 would be more appropriate. For my too cents worth (and I'm not a bird owner), you would be much better off with higher amperage batteries, and 6 volt golf cart batteries would be much better for battery life and boondocking. The 6 volt golf cart batteries are true deep cycle by design. Marine/deep cycle are a compromise between regular starting batteries and true deep cycle, and don't perform either function as well as batteries dedicatedfor that purpose.
Gary
SOB
12-06-2008, 12:02
For a starting point, assume the less-than-new batteries still have
75% of their original 85AH capacity. The total capacity of the 4 batteries would be (4 X 85 X .75) = 255 AH. A good rule of thumb says that only a 50% discharge should be allowed (voltage at 50% would be almost exactly 12), so the real available power is 255/2 ~ 128 AH. Because the Cat will require about this much power to crank, there would little reserve power for the coach interior. (Note that with 4 fresh golf cart batteries - the original BB design, these numbers would roughly double.) Suppose the bus were equipped with a separate battery to crank the Cat (a split battery system). In this case, there should be about 128/6 or 22 hours of battery available for "sleep condition" with the existing batteries. These are all "bench racing" numbers. Differing conditions and interpretations could lead to a bit of change to the bottom line, but this covers the general idea when the same batteries are used for automotive and house systems. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > I'm still struggling with trying to figure out if my batteries are > trashed or somehow I have an inordinately high current drain. > > The facts; > 4 - 12volt - 85ah marine deep cycle batteries in parallel > Batteries have been fully charged w/ external charger to 14.5+volts > current drain with almost everything off (sleep condition) = 6amps > measured with a good quality clamp ammeter > > Question > How long should healthy batteries be able to maintain cranking voltage? > > Regards, > GPSGary > |
