Propane sensor/detector 1980 FC33
03-15-2009, 09:55
Just checked out my LPG system. Seems to work as designed generally. I also
checked out the original LifeGuard LPG and CO detector system. I tested the LPG detectors with an unlit propane torch. None work. One is absent and one is melted. Did a search and found this set of sensors http://www.futurlec.com/Gas_Sensors.shtml but they do not look at all like my little white plastic roach hotel style sensors. Are the original ones available? It has only been 29 years. John Churchill LARGE MARGE 1980 FC33 Sanibel, FL |
