Heater rocker switches
06-08-2005, 05:39
They are the same switch, through early '00 I believe. After that,
the change from the original (Chicago?) "shiny" switch to the softer-
looking textured-finish. SPDT, Center Off.
- Jeff Miller
> Dan,
> A local electronics store should have them. Or, call Bluebird and
ask if
> they are the same rocker switches as in the 1986 and 1987 PT38. If
they
> are, the electronics store near my house carries them and I can get
them
> for you, and cheaper than Bluebird at $8.40 ea. + shipping. Only
> difference I found was the finish was bright vs. satin...you can't
tell
> unless you spend time looking at the them.
> Curt Sprenger `87PT38, Anaheim, Calif.
> Dan Carr wrote:
> > Does anyone know where to find replacements for the off-low-high
> > rocker switch for the front heaters and defrosters. The driver's
side
> > heater switch is defunct and the important (passenger-side) heater
> > switch is starting to go (won't turn off without lots of
> > manipulation). Switches for the defrosters are also heading south.
> > I looked in the parts DB and didn't see anything (but my better
half
> > says I couldn't find things with two hands and a flashlight)
> > Any help would be greatly appreciated.
> > Dan Carr
> > 82 PT40 6V92
> > Eastern Ohio
