starter
05-12-2009, 15:05
starter
Hi All
Had a great weekend by the beach . Monday I was ready to drive the bus to storage . Would not start , after following some good advise I was able to start the engine .Good size hammer a few shots to the starter while someone turns the key, did it . Hi Tech !! Now scheduling the proper replacement . Thanks for the help. Mario 1985fc35 Safely in storage in Vista |
05-13-2009, 02:54
starter
Mario,Sounds like you need a new starter solenoid.
Harold Prescott 1985 WLFC 35 Butte County Ca. --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Hi All > Had a great weekend by the beach . Monday I was ready to drive the bus to storage . Would not start , after following some good advise I was able to start the engine .Good size hammer a few shots to the starter while someone turns the key, did it . Hi Tech !! > Now scheduling the proper replacement . Thanks for the help. > Mario 1985fc35 Safely in storage in Vista > |
05-13-2009, 15:44
starter
Harold , Thanks . Having the work done , looking to have my starter solenoid
reman .Do you still have the original starter ? Mario 1985fc35 Socal --- In WanderlodgeForum@yahoogroups.com, "Harold Prescott" wrote: > > Mario,Sounds like you need a new starter solenoid. > > Harold Prescott > 1985 WLFC 35 > Butte County Ca. > > > > --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > > > Hi All > > Had a great weekend by the beach . Monday I was ready to drive the bus to storage . Would not start , after following some good advise I was able to start the engine .Good size hammer a few shots to the starter while someone turns the key, did it . Hi Tech !! > > Now scheduling the proper replacement . Thanks for the help. > > Mario 1985fc35 Safely in storage in Vista > > > |
05-14-2009, 03:22
starter
Mario,
I don't know if the starter is original or not. Going by the miles on my coach, I would say it's original. 160K The solenoid can be R&R'ed without replacing the starter. NAPA will carry the solenoid. There is a electrical rebuild shop in Escondido. North County Rebuilders - (760) 746-2276. 445 No. Hale., Escondido, Ca. I've used this shop in the past with good results. It's only a rebuild shop, you will need to hand carry the starter into them. Good Luck with all this Harold --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Harold , Thanks . Having the work done , looking to have my starter solenoid reman .Do you still have the original starter ? > Mario 1985fc35 Socal > --- In WanderlodgeForum@yahoogroups.com, "Harold Prescott" wrote: > > > > Mario,Sounds like you need a new starter solenoid. > > > > Harold Prescott > > 1985 WLFC 35 > > Butte County Ca. > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > > > > > Hi All > > > Had a great weekend by the beach . Monday I was ready to drive the bus to storage . Would not start , after following some good advise I was able to start the engine .Good size hammer a few shots to the starter while someone turns the key, did it . Hi Tech !! > > > Now scheduling the proper replacement . Thanks for the help. > > > Mario 1985fc35 Safely in storage in Vista > > > > > > |
