83 35FC fuel transfer pump location
08-26-2009, 03:19
does anyone know the location of the fuel transfer pump located between the tank
and the racor. Is it on the cross menmber or the left rear chassis near the
tank. I was told it was on the frame back at the tank drivers side but can't
locate it.
08-26-2009, 07:16
I had an '81FC and it did not have one, just the fuel lift pump on the engine. Several folks have addeda Facet pump in-line along the framewith good results.
Sent: Wednesday, August 26, 2009 8:19 AM
Subject: [WanderlodgeForum] 83 35FC fuel transfer pump location
does anyone know the location of the fuel transfer pump located between the tank and the racor. Is it on the cross menmber or the left rear chassis near the tank. I was told it was on the frame back at the tank drivers side but can't locate it.
08-26-2009, 11:27
I’m in the process of doing that very thing with my ’84.
I can supply part #’s if you need them and will post pix when I’m
done.
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of larryalb
Sent: Wednesday, August 26, 2009 8:20 AM
08-26-2009, 12:59
My 84 has one mounted above and just behind the rear axle, about even with the
streetside edge of the fuel tank.
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "Peter Goddu" wrote:
> I'm in the process of doing that very thing with my '84. I can supply part
> #'s if you need them and will post pix when I'm done.
> can't locate it.
