Proper weight of gear lube oil in differential
06-14-2005, 22:12
I've got a slight dilemma regarding which gear lube oil
to run in my differential. I consulted an industry expert who owns a heavy duty fleet maintenance shop and works on trucks all day. He said that GL-5 80W90 gear lube oil would be fine in my Rockwell 5.29 gear ratio differential. That's what I put in. Digging through my Blue Box, I accidently ran across some papers that stated Rockwell advised using 85W140 oil. Since my Bird is so old, I wonder if lubrication technology has made that recommendation obsolete, or if I should switch to that weight. The lubricants made in 1981 are a far cry from what's available today. The book also stated that, if you drive less than 60,000 miles per year, the gear lube should be replaced twice a year, Spring and Fall. That's what I'll do. Any experience on gear lube weights? George Witt 81 FC 35 Lincoln, Nebraska (60 miles down the road from the College World Series--Huskers play Friday night) |
06-15-2005, 01:05
Yep same here,
Twice a year seems a bit much, I think this was the first change for our 88. This could start the viscosity debate again. Bill FC Michigan no leaky read end here --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > I've got a slight dilemma regarding which gear lube oil > to run in my differential. > I consulted an industry expert who owns a heavy duty > fleet maintenance shop and works on trucks all day. He > said that GL-5 80W90 gear lube oil would be fine in my > Rockwell 5.29 gear ratio differential. > That's what I put in. > Digging through my Blue Box, I accidently ran across > some papers that stated Rockwell advised using 85W140 oil. > Since my Bird is so old, I wonder if lubrication > technology has made that recommendation obsolete, or if > I should switch to that weight. > The lubricants made in 1981 are a far cry from what's > available today. > The book also stated that, if you drive less than > 60,000 miles per year, the gear lube should be replaced twice > a year, Spring and Fall. > That's what I'll do. Any experience on gear lube weights? > > George Witt > 81 FC 35 > Lincoln, Nebraska (60 miles down the road from the > College World Series--Huskers play Friday night) |
06-15-2005, 03:21
Bill: I've alway's used the 85-140wt. I've used it in the last 3
coach's. I change it once a year and use amsoil synthetic. Never had a problem...Bob 93pt Illinois > > Twice a year seems a bit much, I think this was the first change > for our 88. This could start the viscosity debate again. > > > Bill FC Michigan no leaky read end here > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > <mrdonut12@y...> wrote: > > I've got a slight dilemma regarding which gear lube oil > > to run in my differential. > > I consulted an industry expert who owns a heavy duty > > fleet maintenance shop and works on trucks all day. He > > said that GL-5 80W90 gear lube oil would be fine in my > > Rockwell 5.29 gear ratio differential. > > That's what I put in. > > Digging through my Blue Box, I accidently ran across > > some papers that stated Rockwell advised using 85W140 oil. > > Since my Bird is so old, I wonder if lubrication > > technology has made that recommendation obsolete, or if > > I should switch to that weight. > > The lubricants made in 1981 are a far cry from what's > > available today. > > The book also stated that, if you drive less than > > 60,000 miles per year, the gear lube should be replaced twice > > a year, Spring and Fall. > > That's what I'll do. Any experience on gear lube weights? > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska (60 miles down the road from the > > College World Series--Huskers play Friday night) |
06-15-2005, 22:07
wrotey night) Here is more than you will ever want to know about differential lubes. I ended up putting in 75W90 in the old 86 I had and have it in the new 04. This string of emails is best read from the bottom up. From: McGlone, Bruce [Bruce.McGlone@...] Sent: Friday, January 14, 2005 8:34 AM To: Cole, Ronald; 'jescoggins@...' Subject: RE: Axle / Differential Lubricant for R125NX8 342 Axle Jim; Thank you for your response. Pennzoil's EW 80W/140 is one of the many approved SAE 80W/140 gear oils referenced on our upcoming oil approval list. If needed, this lubricant is also listed on the database of SAE J2360-approved gear oils as Approval PRI GL0025. This list is located at web address http://www.pri.sae.org/PRI/IMprograms/Lu...report.pdf <http://www.pri.sae.org/PRI/IMprograms/Lu...report.pdf> . Per your original question, there should be no performance problems or compatibility problems with ArvinMeritor seals if a carrier were to be refilled with this oil. I hope that this answers your questions. If you need additional information, please contact me at the numbers noted below. Regards, Bruce F. McGlone, Senior Chemist, ArvinMeritor Materials Engineering Office: RD-152 Phone: USA (248) 435-9929 Fax: USA (248) 435-6602 e-mail: Bruce.McGlone@... = = = = = = = = = = = = = = = = = = = = = = = <<...OLE_Obj...>> > -----Original Message----- > From: James Scoggins [mailto:jescoggins@... > > Sent: Thursday, January 13, 2005 7:23 PM > To: 'Cole, Ronald' > Subject: RE: Axle / Differential Lubricant for R125NX8 342 Axle > > > Thank you for your time and for the response. > > Here is all the info on the bucket of gear lube: > > Pennzoil FCI > Gearplus R Super EW > Synthetic Gear Oil > SAE 80W140 > API GL-5/MT-1 > Dana SHAES 234 > SHAES 256 > Arvin Meritor O-76 > Mack GO-5 > > From what I read this stuff should have been OK? > > Regards, > Jim Scoggins > > -----Original Message----- > From: Cole, Ronald [mailto:Ronald.Cole@... > > Sent: Thursday, January 13, 2005 4:05 PM > To: 'jescoggins@...' > Cc: McGlone, Bruce; Vickers, Douglas > Subject: RE: Axle / Differential Lubricant for R125NX8 342 Axle > > Jim Scoggins / Stafford, VA > > Ref: Our two (2) telephone conversations today > > Here is some input from our Senior Chemist, Bruce McGlone. Believe > that you probably were using the 80W/140 syn lube and I probably wrote > down the wrong viscosity grade. > > If you wish to have Mr. McGlone advise you on specifics please feel > free to contact him. > > You can get more information on our lubricant recommendations by going > to the ArvinMeritor web site at > http://www.arvinmeritor.com/tech_library...=19&sub=45 > <http://www.arvinmeritor.com/tech_library...=19&sub=45> > <http://www.arvinmeritor.com/tech_library...=19&sub=45 > <http://www.arvinmeritor.com/tech_library...=19&sub=45> > > . Go to Section 8: Rear Drive Axles, page 150, for current oil lube > specifications. > > The differential carrier pinion oil seal is a unitized type of seal, > our part number A 1205N2588. This seal is perfectly compatible with > either petroleum base of synthetic lubricants. > > I do not know the oil bath (wheelend) seal that Blue Bird installed or > uses for servicing the hub/drum assemblies in the R125NX8 342 axles as > Blue Bird supplied / installed the hub/drum assemblies themselves. > You might want to confirm to your satisfaction that these seals are > adequate for synthetic lubricants. Based on my dealings with Blue > Bird on the current drive axle used in the Wanderlodge (ArvinMeritor > RC23161 Series > Axle) the wheelend oil bath oil seal assembly is ArvinMeritor A 1205V2492. > This seal is perfectly compatible with either petroleum base or synthetic > lubricants and could be used with the hubs/drum assemblies assembled to > the R125NX8 342 axle. > > Incidentally, ArvinMeritor currently supplies to Blue Bird completely > built up axles with lubricant already filled. When synthetic > lubricant is required we fill with SAE 75W/90 synthetic lubricant. > > Please advise if you have further questions. > > Regards, > > Ron Cole > Manager, Applications and Customer Support > Specialty Products Engineering > 444 Hebron Road > Heath, OH 43056-1440 > Tel: 740-348-3470 > Fax: 740-348-3608 > E-mail: Ronald.Cole@... > > > > > -----Original Message----- > > From: McGlone, Bruce > > Sent: Thursday, January 13, 2005 3:00 PM > > To: Cole, Ronald; Vickers, Douglas > > Subject: RE: Axle / Differential Lubricant for R125NX8 342 Axle > > > > Ron; > > > > Good question. > > > > The 80W/140 visc. grade was not approved by most OEMs (including us) > > for > a long time (>10 yrs.) because of reasons involving shear stability. > Since the current oil-approval spec includes a shear-stability > requirement (thanks to GM and us), the 80W/140 visc. grade > specification has been brought out of mothballs and is now a current > ARM document; the MM#1 document needs to be revised accordingly. > > > > FYI: The TP9539 extended-oil-drain approval document has recently > > been > extensively re-written (me) and the soon-to-be-issued document lists a > lot of new approvals, as well as the 80W/140 gear oil spec. for SAE > J2360-approved (!!!) gear oils. > > > > Regards, > > Bruce F. McGlone, Senior Chemist, ArvinMeritor Materials Engineering > > Office: RD-152 > > Phone: USA (248) 435-9929 [Comnet 525-9929] > > Fax: USA (248) 435-6602 [Comnet 525-6602] > > e-mail: Bruce.McGlone@... > > = = = = = = = = = = = = = = = = = = = = = = = > > > > -----Original Message----- > > From: Cole, Ronald > > Sent: Thursday, January 13, 2005 2:44 PM > > To: McGlone, Bruce; Vickers, Douglas > > Subject: RE: Axle / Differential Lubricant for R125NX8 > 342 > > Axle > > > > Bruce - > > > > I probably just wrote down the wrong grade - I know he said '140' > > so > it was probably 80W/140 that he used. > > > > I just checked MM1, Section 8, page 150 and it says syn lube > available in 75W/140 or 75W/90 but does not mention 80W/140 as being > approved. > > > > Can you comment as to whether we can tell him 80W/140 is OK? > > > > Regards, > > > > Ron > > > > -----Original Message----- > > From: McGlone, Bruce > > Sent: Thursday, January 13, 2005 2:28 PM > > To: Cole, Ronald; Vickers, Douglas > > Subject: RE: Axle / Differential Lubricant for > > R125NX8 342 Axle > > > > Gentlemen; > > > > If the motor home's axle/seals are "used to" synlube then, > by all means, keep it there. > > > > I should mention though, that there are no synlubes with > this viscosity grade. Synthetic gear oils are marketed in (primarily) > 75W/90 and 80W/140 viscosity grades, with a few 75W/140 oils ($$$$). > There are a few extended-drain petroleum-based gear oils that have > been tested and approved by us, including at least one (Chevron ESI) > that's an 85W/140, but these aren't synthetics. If needed, I can get > further information on the properties of the customer's gear oil if > he/she provides a brandname and viscosity grade (Example: "Chevron > UPM Universal 80W/90"). > > > > If the customer is happy with their oil, let's advise them > to leave the same variety in there. > > > > > > Regards, > > Bruce F. McGlone > > Tel: 248-435-9929 > > ============= > > > > -----Original Message----- > > From: Cole, Ronald > > Sent: Thursday, January 13, 2005 1:56 PM > > To: McGlone, Bruce; Vickers, Douglas > > Subject: Axle / Differential Lubricant for > R125NX8 342 Axle > > > > Bruce / Doug - > > > > I got a call today from an owner of a 1986 Blue Bird > Wanderlodge motor home with subject axle. He had a recent > 'differential failure' after 122,000 miles and he is getting it > repaired. He had been > using 85W/140 synthetic lubricant and wants > our advice on whether it is OK to continue to use this lube when the > unit is repaired. > > > > The R125NX8 carrier is basically an inverted (Rear > Engine Drive) R155 carrier. > > > > Any comments you can provide? > > > > I'll address issues with pinion and wheelend oil > seals. > > > > Regards, > > > > Ron > > |
