					Need help with water system question, 88 pt40 96"
					06-16-2005, 06:51
				 Post: #1 | |||
					We have been running our 88 pt40 on dirrect hook up water with 40psi for around a month now, yesterday the water pressure dropped very low in the coach. The inlet psi is still 40. If we turn the pump on we have lots of pressure. With the pump off we will have pressure for just a second when you first open something up and then it drops off rapidly. If we kick the electric air compressor on we will get pressure for a second and then air blowing through the lines. Is the air compressor tied into the fresh water somewhere? The switch next to the fresh water connection is not on fill. Could a solenoid be stuck? Where shoud I start looking. Thanks in advance for the help. Tom C. Wa state | |||
					06-16-2005, 07:26
				 Post: #2 | |||
					tom, did someone flip the switch at the base of the bed for purging the system? ernie [Non-text portions of this message have been removed] | |||
					06-16-2005, 11:10
				 Post: #3 | |||
					it sounds like the air purge switch in the bedroom is on,allowing air into your pipes.randydupree93wb ----- Original Message ----- From: hodakaguy To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 16, 2005 2:51 PM Subject: [WanderlodgeForum] Need help with water system question, 88 pt40 96" We have been running our 88 pt40 on dirrect hook up water with 40psi for around a month now, yesterday the water pressure dropped very low in the coach. The inlet psi is still 40. If we turn the pump on we have lots of pressure. With the pump off we will have pressure for just a second when you first open something up and then it drops off rapidly. If we kick the electric air compressor on we will get pressure for a second and then air blowing through the lines. Is the air compressor tied into the fresh water somewhere? The switch next to the fresh water connection is not on fill. Could a solenoid be stuck? Where shoud I start looking. Thanks in advance for the help. Tom C. Wa state ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] | |||
					06-16-2005, 16:33
				 Post: #4 | |||
					Thanks, it was a combo of a couple problems.  The switch was turned on so that was a easy fix. The low water pressure problem ended up being a bad water pressure requlator at the hose connection. I like fixes like this. Thanks agian. Tom C. --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > it sounds like the air purge switch in the bedroom is on,allowing air into your pipes.randydupree93wb > ----- Original Message ----- > From: hodakaguy > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 16, 2005 2:51 PM > Subject: [WanderlodgeForum] Need help with water system question, 88 pt40 96" > > > We have been running our 88 pt40 on dirrect hook up water with 40psi > for around a month now, yesterday the water pressure dropped very low > in the coach. The inlet psi is still 40. If we turn the pump on we > have lots of pressure. With the pump off we will have pressure for > just a second when you first open something up and then it drops off > rapidly. If we kick the electric air compressor on we will get > pressure for a second and then air blowing through the lines. Is the > air compressor tied into the fresh water somewhere? The switch next > to the fresh water connection is not on fill. Could a solenoid be > stuck? Where shoud I start looking. Thanks in advance for the help. > > Tom C. Wa state > > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
