PT Engine Cooling Fan System
08-05-2007, 14:11
Has anyone figured out how the PT engine cooling fan system actually changes
from low speed to high? Obviously there is a fan override switch on the dash and a temperature controlled switch on the engine which when activated turns the fan on high. Question is, what do they really turn on? or off? thanks, Rick Archie 85PT40 Fort Worth |
08-05-2007, 14:26
There's a thermostat somewhere... however, the fan goes to 'high'
when (1) the dash switch "fan Override" is on and (2) whenever the chassis AC is on. When the switch is off and the AC is off, then the thermostat (where ever it is) controls the fan speed. On my coach, I can't ever tell when the fan is off or running on low speed -- unless I'm standing outside. I can tell when the fan is on 'high' if I'm parked or moving over dusty (unpaved) ground as the high speed really kicks up the dust. So, unless you want the fan on high all the time, leave the fan override switch "off" and don't turn on the chassis AC. Then, the thermostatically controlled switch (back in the engine compartment somewhere) will control the fan speed. (On my coach, the fan is powered hydraulically.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 5, 2007, at 7:11 PM, Rick A. wrote: > Has anyone figured out how the PT engine cooling fan system > actually changes from low > speed to high? Obviously there is a fan override switch on the dash > and a temperature > controlled switch on the engine which when activated turns the fan > on high. Question is, > what do they really turn on? or off? [Non-text portions of this message have been removed] |
08-05-2007, 14:38
Rick:
There is an alarmstat on the rear of the engine that senses water temperature. When it reaches the correct temperature, it signals the fan to go into high speed. I don't know all the interlocking parts, but that typically is how it works. A failed alarmstat will keep your fan on high all the time. Also, when you turn on the dash air, it signals the fan to run in high mode. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Rick A." > > Has anyone figured out how the PT engine cooling fan system actually changes from low > speed to high? Obviously there is a fan override switch on the dash and a temperature > controlled switch on the engine which when activated turns the fan on high. Question is, > what do they really turn on? or off? > > thanks, > Rick Archie > 85PT40 > Fort Worth > |
08-05-2007, 14:43
Thanks Pete,
But I'm looking for a little more specific information. Like the actual valve which controls the hydraulic fan systems low speed... and likewise for the high speed? There is a Webster Pressure Relief Valve in this system which has a solenoid? No hydraulic shop here can find any information on it, as Webster has been gone awhile. Bluebird parts says they no longer stock it and they do not have service kits for it? Rick Archie 85PT40 Fort Worth...where it has not rained for 2 days... --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > There's a thermostat somewhere... however, the fan goes to 'high' > when (1) the dash switch "fan Override" is on and (2) whenever the > chassis AC is on. > > When the switch is off and the AC is off, then the thermostat (where > ever it is) controls the fan speed. On my coach, I can't ever tell > when the fan is off or running on low speed -- unless I'm standing > outside. I can tell when the fan is on 'high' if I'm parked or moving > over dusty (unpaved) ground as the high speed really kicks up the dust. > > So, unless you want the fan on high all the time, leave the fan > override switch "off" and don't turn on the chassis AC. Then, the > thermostatically controlled switch (back in the engine compartment > somewhere) will control the fan speed. (On my coach, the fan is > powered hydraulically.) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 5, 2007, at 7:11 PM, Rick A. wrote: > > > Has anyone figured out how the PT engine cooling fan system > > actually changes from low > > speed to high? Obviously there is a fan override switch on the dash > > and a temperature > > controlled switch on the engine which when activated turns the fan > > on high. Question is, > > what do they really turn on? or off? > > > > [Non-text portions of this message have been removed] > |
08-05-2007, 16:50
Well my friend, I think you have it. I didn't know the name but on my coach it
is located on the street side frame rail. It hydraulic over electric. I believe that the electric sensor/switch is still available, though I'm at a loss to tell you where. This is one of the things on these old birds that are no longer available. Though I imagine that a good hydraulic shop could probably overhaul it if it is inside the valve itself. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Rick A. To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 05, 2007 7:43 PM Subject: [WanderlodgeForum] Re: PT Engine Cooling Fan System Thanks Pete, But I'm looking for a little more specific information. Like the actual valve which controls the hydraulic fan systems low speed... and likewise for the high speed? There is a Webster Pressure Relief Valve in this system which has a solenoid? No hydraulic shop here can find any information on it, as Webster has been gone awhile. Bluebird parts says they no longer stock it and they do not have service kits for it? Rick Archie 85PT40 Fort Worth...where it has not rained for 2 days... --- In WanderlodgeForum@yahoogroups.com Masterson > > There's a thermostat somewhere... however, the fan goes to 'high' > when (1) the dash switch "fan Override" is on and (2) whenever the > chassis AC is on. > > When the switch is off and the AC is off, then the thermostat (where > ever it is) controls the fan speed. On my coach, I can't ever tell > when the fan is off or running on low speed -- unless I'm standing > outside. I can tell when the fan is on 'high' if I'm parked or moving > over dusty (unpaved) ground as the high speed really kicks up the dust. > > So, unless you want the fan on high all the time, leave the fan > override switch "off" and don't turn on the chassis AC. Then, the > thermostatically controlled switch (back in the engine compartment > somewhere) will control the fan speed. (On my coach, the fan is > powered hydraulically.) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 5, 2007, at 7:11 PM, Rick A. wrote: > > > Has anyone figured out how the PT engine cooling fan system > > actually changes from low > > speed to high? Obviously there is a fan override switch on the dash > > and a temperature > > controlled switch on the engine which when activated turns the fan > > on high. Question is, > > what do they really turn on? or off? > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
08-05-2007, 20:03
That control and hoses that run into it are to the rear of the tag axle mud
flap on the street side. I know when I had to get under there to remove a hose that went to my cooling fan motor for the radiator. Hope yours isn't as messy as mine was~ Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-06-2007, 01:06
There is an Alarmstat control that actuates a hydraulic valve that controls fan
speed. Full on or Idle. All factory Alarmstats I have seen are 195 degree and in the absence of the fan override or chassis air being on the water temperature gauge should cycle between 200 and 190 degrees. The hydraulics of the fan partially bypass when in idle mode and full on in high mode. The reservoir is the big black tank on the road side of the engine bay. It is also the reservoir for the power steering system. Don't forget it has three filters inside. I changed my Alarmstat to 190 degrees and run lower temperatures now. It is manufactured by Medallion Instruments and is available from BB. It is located in the water jacket near the water pump adjacent to the water temp sender. It has two wires. I have an electrical drawing for the fan circuit for a 1990. I imagine all would be the same since I doubt BB reinvented the system each year. I do not have a schematic of the valve. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Rick A. To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 05, 2007 9:11 PM Subject: [WanderlodgeForum] PT Engine Cooling Fan System Has anyone figured out how the PT engine cooling fan system actually changes from low speed to high? Obviously there is a fan override switch on the dash and a temperature controlled switch on the engine which when activated turns the fan on high. Question is, what do they really turn on? or off? thanks, Rick Archie 85PT40 Fort Worth [Non-text portions of this message have been removed] |
