Passenger Door Day Shade
02-06-2011, 15:36
The String that operates the Day & Night Shade to the Passenger Door snapped and
was wondering if there is an Easy way to fix it w/o taking the inner Door Panel off? Has this happen to anyone else? Can you simply replace it by buying a Custom Shade that mounts to the inner frame of the Passenger Door Window? I apologize for the 20 questions but was just looking for a solution ![]() Thanks Tim V. Romoland Ca 94pt 40WB |
02-06-2011, 16:02
Hi Tim,
I am sure there is a more complex way of doing this, but on my SP36 BB the drivers side window shade string system broke .
I pulled it out and took it to an independent shade retailer and he had a guy re-string it for me.
Fred & Jeanne Hulse
Morristown,Arizona 97 WLWB41 |
02-07-2011, 06:10
Need to take it off in order to repair that blind.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "TimV" > > The String that operates the Day & Night Shade to the Passenger Door snapped and was wondering if there is an Easy way to fix it w/o taking the inner Door Panel off? Has this happen to anyone else? Can you simply replace it by buying a Custom Shade that mounts to the inner frame of the Passenger Door Window? I apologize for the 20 questions but was just looking for a solution ![]() > > Thanks > > Tim V. > Romoland Ca > 94pt 40WB > |
