fc newbie questions
03-06-2011, 05:51
fc newbie questions
hello
i just purchased a 1978 fc32? after some reading i realize its either a 31 or 33, how do i tell the difference? have some questions the wanderlodge has air ride added and when it turns it seems to lean a lot,is that normal? it has a good 3208na, i have a 3208t, is it worth putting the turbo motor in place of the na?can do work myself. does this allison have a trans retarder and how does it work? it only has a 50amp power recepticle with cords to adapt to 110 does this have a 220 curciut built into the system also? wish there was someone local to show how all the things work! dana 40 miles east of stockton ca |
03-08-2011, 00:49
fc newbie questions
--- In WanderlodgeForum@yahoogroups.com, "df0226"
> > hello > i just purchased a 1978 fc32? > after some reading i realize its either a 31 or 33, how do i tell the difference? > have some questions > the wanderlodge has air ride added and when it turns it seems to lean a lot,is that normal? > it has a good 3208na, i have a 3208t, is it worth putting the > turbo motor in place of the na?can do work myself. > does this allison have a trans retarder and how does it work? > it only has a 50amp power recepticle with cords to adapt to 110 > does this have a 220 curciut built into the system also? > wish there was someone local to show how all the things work! > > dana > 40 miles east of stockton ca i just purchased a 1978 fc32? after some reading i realize its either a 31 or 33, how do i tell the difference? Measuring tape? The 31 will be approx 2 feet shorter than... ![]() > |
03-08-2011, 06:04
fc newbie questions
Dana, The actual measurements of a so called FC 31 isn't exactly 31 feet. Someone told me that my FC31 was called the "State Park" model I think, because there were length restrictions on RV's in some parks, and Bluebird tried to capitalize on that. I would imagine that the 33' and the 35' are not exactly their true measurements either. To find out the length of mine, my brother held a 2x4 up against the front bumper, and I measured as far as my tape measure would go down the side of the bus, around 25' if I remember, then he moved to the rear bumper and I measured to there. Whatever the total of the two measurements was, it was closer to 31' than 33', so we figured that it was 31'. I later verified that it was a 31 footer via two previous owners. Good Luck, George Burke 1977 FC31 Charlotte
On Tue, Mar 8, 2011 at 7:49 AM, Dick <"giderich@fidnet.com"> wrote:
03-08-2011, 07:08
fc newbie questions
03-08-2011, 16:17
fc newbie questions
