Breaker Issues in Upper 90's
06-07-2011, 16:35
Hey Folks,
Im in the Hot and Sunny South. I'm plugged up to 50 amp service. My upper dash gauges... Leg One Volts reads left of 60 volts, Leg Two Volts reads 125... My Leg One Amp gauge reads 0, Leg two reads normally as it fluctuates to the pull of the air conditioners and appliances... If I run all three air conditioners and I turn on the water heater it kicks the breaker out on the pole. I can run two air conditioners and the water heater ok... It just seems that everything thing is on Leg Two... Never had this problem before now. I've always been able to run everything at once with no issues... Help if you can... Thanks Ray and Denise 92 Wanderlodge Nashville TN |
06-07-2011, 17:23
06-07-2011, 23:16
06-08-2011, 02:06
I suspect low shore voltage due to high usage or another shore power problem.
Test the shore outlet. It should read 120V from either side to neutral (also either side to ground) and 240 volts across the two hots. Remember that, certain inductive loads will draw more current when the voltage drops thereby causing overloads. On coaches with three air conditioners it should be wired so two are on one leg and one on the other (probably the water heater is on thew leg with the one air conditioner). --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > Ray, start your generator and see where your voltage meters go. If they both show 125, then maybe your power cable is faulty > > > Ernie Ekberg > 88 PT40 > 817-475-3991 > http://www.ernieekbergflooring.net > > --- On Tue, 6/7/11, Ray > > > From: Ray > Subject: [WanderlodgeForum] Breaker Issues in Upper 90's > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, June 7, 2011, 11:35 PM > > > Ã > > > > Hey Folks, > Im in the Hot and Sunny South. I'm plugged up to 50 amp service. My upper dash gauges... Leg One Volts reads left of 60 volts, Leg Two Volts reads 125... > My Leg One Amp gauge reads 0, Leg two reads normally as it fluctuates to the pull of the air conditioners and appliances... If I run all three air conditioners and I turn on the water heater it kicks the breaker out on the pole. I can run two air conditioners and the water heater ok... It just seems that everything thing is on Leg Two... Never had this problem before now. I've always been able to run everything at once with no issues... Help if you can... Thanks > > Ray and Denise > 92 Wanderlodge > Nashville TN > |
