Water check valve problem?
07-07-2011, 00:13
Hello all, I am a new owner of an '83 FC35. I have been going through some of
the systems on the bus, cleaning and learning a lot. After doing searches on this forum to solve my problem, I still am confused. The problem I am experiencing is with the water filling and pumping. The water pump seemed to be working fine until the fresh water tank emptied. I recognized it was empty right away and filled tank. ( water was coming out of overflow} Pressure seemed fine for the rest of the evening while using the kitchen sink. The next day when I tried to use the sink, the pressure from the pump was very low and no water at all when I turned to the hot water. Pump runs continously. I disconnected the inlet hose to the Flojet pump thinking maybe airlock-lost prime, while it was running but that didnt change anything. Also, I thought I would give a try at using "direct water hookup",(city water), which gives me hot water and good pressure but it is pouring out the overflow of fresh water tank while hooked up. Is this where the check valve is bad? What does it look like? I have the area under the bed open but there are a lot valves there. I recognize a pressure regulator but this is all new to me. Thanks in advance for any suggestions or help. Jeff Lawrence Panama City Beach,FL. 850-527-1085 |
07-07-2011, 08:26
07-07-2011, 08:30
Hi jeff:
Switch off the tank fill switch. Though your Sporlan valve may need looking at. The fill switch controls the coil of the Sporlan valve and that valve is the diverter valve for coach and shore water. Remember, when you fill your coach tank, first turn off your pump, it will cycle because it senses the drop in pressure and tries to run to catch up. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "jepetto58" Sender: WanderlodgeForum@yahoogroups.com Date: Thu, 07 Jul 2011 12:13:40 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Water check valve problem? Hello all, I am a new owner of an '83 FC35. I have been going through some of the systems on the bus, cleaning and learning a lot. After doing searches on this forum to solve my problem, I still am confused. The problem I am experiencing is with the water filling and pumping. The water pump seemed to be working fine until the fresh water tank emptied. I recognized it was empty right away and filled tank. ( water was coming out of overflow} Pressure seemed fine for the rest of the evening while using the kitchen sink. The next day when I tried to use the sink, the pressure from the pump was very low and no water at all when I turned to the hot water. Pump runs continously. I disconnected the inlet hose to the Flojet pump thinking maybe airlock-lost prime, while it was running but that didnt change anything. Also, I thought I would give a try at using "direct water hookup",(city water), which gives me hot water and good pressure but it is pouring out the overflow of fresh water tank while hooked up. Is this where the check valve is bad? What does it look like? I have the area under the bed open but there are a lot valves there. I recognize a pressure regulator but this is all new to me. Thanks in advance for any suggestions or help. Jeff Lawrence Panama City Beach,FL. 850-527-1085 ------------------------------------ Yahoo! Groups Links |
