Discussion Desired on BWT Replacement
10-30-2011, 09:59
Howdy.
We are realizing that there were repairs to the black water tank by previous owners of our 1993 Wanderlodge. I have found seeping where the tank makes a 90 degree corner. Repaired that. Now, there is seeping where the tank and sewer pipe are joined and there is a hose clamp there. So I found seepage on that. So I coated it liberally with silicon caulk. SHMBO is not happy and would like to replace the present tank with one that is not so oddly shaped. Have you replaced the black water tank in your BB? A slightly smaller tank would be o.k. Comments, ideas, please? TIA, Jack
__________________
Regards, Jack and Liz Pearce Fulltiming in a 1993 WLWB Summering in Buena Vista, CO Wintering in Dhanis, Republic of Texas SKPs |
10-30-2011, 10:12
10-30-2011, 10:25
I have a used one if you need one Sent via BlackBerry by AT&T From: Ernie Ekberg Date: Sun, 30 Oct 2011 14:12:20 -0700 (PDT) To: Subject: Re: [WanderlodgeForum] Discussion Desired on BWT Replacement
10-30-2011, 16:51
My experience is that Silicon Calk will - Chuck From: Howdy. __________________ |
11-13-2011, 15:13
Howdy, Chuck.
Thanks for the reply. I don't think our BWT is fiberglass. I think that it is some kind of poly-plastic. Jack ====================================================================== --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > My experience is that Silicon Calk will not hold. I do not know about a '93 > but on our '83 the tanks are fiberglass. Easy to repair with West systems > products. If you are interested I can get the numbers from the product > series we used. I have repaired three tanks and had not had any further > problems. One had a shattered flange where the drain connected, one had > road damage, and one on another coach had a leak where the tank washer was > installed. > > > > - Chuck Wheeler- > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of txfulltimers > Sent: Sunday, October 30, 2011 3:59 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Discussion Desired on BWT Replacement > > > > > > Howdy. > We are realizing that there were repairs to the black water tank by previous > owners of our 1993 Wanderlodge. I have found seeping where the tank makes a > 90 degree corner. Repaired that. Now, there is seeping where the tank and > sewer pipe are joined and there is a hose clamp there. So I found seepage on > that. So I coated it liberally with silicon caulk. SHMBO is not happy and > would like to replace the present tank with one that is not so oddly shaped. > Have you replaced the black water tank in your BB? A slightly smaller tank > would be o.k. Comments, ideas, please? > > TIA, > Jack > > __________________ > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 WLWB > Summering in Buena Vista, CO > Wintering in Dhanis, Republic of Texas > SKPs > > > <http://www.wanderlodgeownersgroup.com/fo...post&p=133 > 552> Edit/Delete Message > |
11-14-2011, 00:30
11-14-2011, 00:55
Try plumbing goop it comes in a tube and sets up hard
Connected by DROID on Verizon Wireless -----Original message-----
