1983 FC35SB @ EBAY Done on 03-01-16
02-27-2016, 14:40
FYI
1983 FC35SB http://www.ebay.com/itm/1983-Wanderlodge...3641.l6368 Pictures, Metalic Beige/Black/White. 38 bids now at $15.1K w/3days remaining 189.1K miles, in Baton Rouge, LA. Selling a great coach after over 20 years of great service, time to down size. It drives straight and quiet down the road great. I drive in the 60-65 MPH at around 10 MPG on flat land and use Power Service fuel additive. If you are looking for a " racer motorhome" this is not one. Wanderlodge coaches are built to last not to go fast. Last time out I noticed a little rear sway and may need rear shocks. The fronts are KONI lifetime and they are the only brand to use on these coaches. New windshields and gasket replaced 3 years ago and of course two rock chips going into Arkansas first trip out. Drive train has runs on Syn. lubes past 15 or so years. Four cyl. Kabota Power-tech generator and I have just replaced the 12 KW power head. Six Michelin XZE2 have around 3,000 miles. I have never had it in snow, ice or salted roads. Differential axle bearings, seals and brake shoes, drums and air components have replaced approximately four years ago. Air valves on gen slide and step were just replaced. Three roof airs, Norcold Ref., two burner gas cook top, Sharp convection oven, double/queen rear bed, king front sofa, twin front sofa. Double rear closets with half closet and drawer unit. Some minor items might need attending. The back-up camera is not working. If you are a serious looker for a Bluebird this is your chance to own a very good one. This has been an exceptional coach with reasonable reserve. I know I will regret selling it but I am getting old and am down sizing. Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
03-03-2016, 14:17
RE: 1983 FC35SB @ EBAY Done on 03-01-16
For the Record...
The seller of this 1983 FC35SB lowered the reserve to the mid 20's and let the bidders know that. The bidding stalled (38 bids) at $15.1K. After 10 days the coach remains unsold. Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
