Grille removal
09-05-2005, 07:45
Grille removal
Anyone out there know the procedure for removing the grille over the
radiator on a 92WB40. The top is held in place with a non-removable
allen head screw anchor of some sort. If you turn it cw till it
stops, it holds firm. If you turn it ccw till it stops, the grille is
loose but will not come off. There has to be a simple trick to this.
09-05-2005, 10:27
Grille removal
O.K. everyone, I figured it out, but BB natched the body too little to
make for easy removal. The three latches at the top of the grille are
similar to drawer locks with a cam, except when in the locked
position, they can be screwed in and tightened.
I am taking my grinder to the notch to improve removal and
installation tolerances.
is
09-05-2005, 10:38
Grille removal
Hey Ron,
Inquiring minds want to know: Why you are taking the radiator grille
off in the first place? Something bad happen?
83 PT40 "Stagecoach" - For Sale
91 PT40 "Texas Minivan"
> is
09-05-2005, 12:04
Grille removal
I wanted to clean any road dirt out of the face of the radiator. It
wasn't bad surprisingly, but a little dirty at the bottom. I don't
want any surprises like overheating when I'm on the road.
Ron
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...>
> Hey Ron,
grille
> Mike Bulriss
> San Antonio, TX
little to
grille are
over the
removable
it
grille
> > is
to this.
09-05-2005, 13:29
Grille removal
Sent: Monday, September 05, 2005 7:04 PM
Subject: [WanderlodgeForum] Re: Grille removal
Ron Blow it out with air water can turn it to mud and when it dryes you will
be worse off also
the water you use may have hi hp.and that can cause your radiator to
deteriorate
Bob Loomas 85 PT 36
Ron
> Hey Ron,
grille
> Mike Bulriss
> San Antonio, TX
little to
grille are
over the
removable
it
grille
> > is
to this.
radiators
YAHOO! GROUPS LINKS
09-05-2005, 13:51
Grille removal
Bob: I used a coil cleaner that the service men use on A/C coils.
It boils out the dirt. I'll finish it off with air, once it has
dried in the morning.
Sure glad to hear from you. I sent you two emails but didn't get
any response. Been keeping up with messages from others.
--- In WanderlodgeForum@yahoogroups.com, bobloomas
> From: ronmarabito2002
dryes you will be worse off also
radiator to deteriorate
> Bob Loomas 85 PT 36
radiator. It
don't
> Ron
<mbulriss@y...>
> > Hey Ron,
> grille
> > Mike Bulriss
> > San Antonio, TX
> little to
> grille are
locked
grille
> over the
> removable
till
> it
> grille
> > > is
trick
> to this.
maintenance
Automotive radiators
> YAHOO! GROUPS LINKS
of Service.
09-05-2005, 14:28
Grille removal
Sent: Monday, September 05, 2005 8:51 PM
Ron My email service was down for two days last week.Fri. & Sat.
Bob Loomas 85 PT 36
maintenance
> YAHOO! GROUPS LINKS
of Service.
radiators
YAHOO! GROUPS LINKS
09-05-2005, 15:42
Grille removal
Well! I'm glad that you and Letty are O.K.
Ron
> Bob Loomas 85 PT 36
Automotive
> maintenance
vehicles
> > YAHOO! GROUPS LINKS
Terms
> of Service.
maintenance
> YAHOO! GROUPS LINKS
of Service.
