Tires and Balancing
09-09-2005, 06:14
Tires and Balancing
Scott- we have equal in our tires- no problems, so far. Ernie-83pt40 in
montana [Non-text portions of this message have been removed] |
09-09-2005, 09:21
Tires and Balancing
Well it looks like our coach "RUBY" will be getting new shoes next
week. New Michelins XZ2 are on the way late July date code!! My question is how do you all balance your tires?? I know a while back there was some discussion; but golf balls and ball bearings don't seem right for some reason. The dealer will install equal for 9.00 per tire if I want it. Anyone using it??? Will it affect in any way any tire pressure monitoring system like "cat eye" (not sure about that one) I am open for opinions on this one its expesive so I want to make sure I do the right thing here...Thanks in advance Scott B 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) |
09-09-2005, 11:01
Tires and Balancing
Scott, use the equal balance, make sure that the installer puts the right valve
core in with the filter and marks the stem so the next tech knows that the tire has equal. Bryan Altier Greenville, SC ----- Original Message ----- From: Scott To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 09, 2005 5:21 PM Subject: [WanderlodgeForum] Tires and Balancing Well it looks like our coach "RUBY" will be getting new shoes next week. New Michelins XZ2 are on the way late July date code!! My question is how do you all balance your tires?? I know a while back there was some discussion; but golf balls and ball bearings don't seem right for some reason. The dealer will install equal for 9.00 per tire if I want it. Anyone using it??? Will it affect in any way any tire pressure monitoring system like "cat eye" (not sure about that one) I am open for opinions on this one its expesive so I want to make sure I do the right thing here...Thanks in advance Scott B 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
09-10-2005, 00:01
Tires and Balancing
Scott,
I have used Equal in the tires of two coaches so far. It is great in that you don't have to worry about re-balancing the tire every so often like you should with weights. Makes the tires last longer and ride smoother. George Lowry '95 WBDA 4203 Spearfish, SD Still trying to get on the road from the birds nest. Bryan Altier wrote: > Scott, use the equal balance, make sure that the installer puts the > right valve core in with the filter and marks the stem so the next > tech knows that the tire has equal. > > Bryan Altier Greenville, SC ----- Original Message ----- From: > Scott To: WanderlodgeForum@yahoogroups.com Sent: Friday, September > 09, 2005 5:21 PM Subject: [WanderlodgeForum] Tires and Balancing > > > Well it looks like our coach "RUBY" will be getting new shoes next > week. New Michelins XZ2 are on the way late July date code!! My > question is how do you all balance your tires?? I know a while back > there was some discussion; but golf balls and ball bearings don't > seem right for some reason. The dealer will install equal for 9.00 > per tire if I want it. Anyone using it??? Will it affect in any way > any tire pressure monitoring system like "cat eye" (not sure about > that one) I am open for opinions on this one its expesive so I want > to make sure I do the right thing here...Thanks in advance > > Scott B 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) > > > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > ------------------------------------------------------------------------------ > > > > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> Get fast access to your favorite Yahoo! > Groups. Make Yahoo! your home page > http://us.click.yahoo.com/dpRU5A/wUILAA/.../pkiolB/TM > --------------------------------------------------------------------~-> > > > > Yahoo! Groups Links > > > > > > > > > > > |
09-10-2005, 00:43
Tires and Balancing
Brian, George, etal, Thanks for the input. Seems many use this type
of "balancing system" One addtional question can you still use the "crossfire" type of monitoring indicators for tire pressure? Scott B 86FC35 "RUBY" Murrells Inlet SC (getting stuff ready today for Ophelia..dang) --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Scott, > > I have used Equal in the tires of two coaches so far. It is great in > that you don't have to worry about re-balancing the tire every so > often like you should with weights. Makes the tires last longer and > ride smoother. > > George Lowry > '95 WBDA 4203 > Spearfish, SD Still trying to get on the road from the birds nest. > > > > Bryan Altier wrote: > > > Scott, use the equal balance, make sure that the installer puts the > > right valve core in with the filter and marks the stem so the next > > tech knows that the tire has equal. > > > > Bryan Altier Greenville, SC > > > ----- Original Message ----- From: > > Scott To: WanderlodgeForum@yahoogroups.com Sent: Friday, September > > 09, 2005 5:21 PM Subject: [WanderlodgeForum] Tires and Balancing > > > > > > Well it looks like our coach "RUBY" will be getting new shoes next > > week. New Michelins XZ2 are on the way late July date code!! My > > question is how do you all balance your tires?? I know a while back > > there was some discussion; but golf balls and ball bearings don't > > seem right for some reason. The dealer will install equal for 9.00 > > per tire if I want it. Anyone using it??? Will it affect in any way > > any tire pressure monitoring system like "cat eye" (not sure about > > that one) I am open for opinions on this one its expesive so I want > > to make sure I do the right thing here...Thanks in advance > > > > Scott B 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) > > > > > > > > > > ------------------------------------------------------------------ ------------ > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service. > > > > > > ------------------------------------------------------------------ ------------ > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------ Yahoo! Groups Sponsor > > --------------------~--> Get fast access to your favorite Yahoo! > > Groups. Make Yahoo! your home page > > http://us.click.yahoo.com/dpRU5A/wUILAA/.../pkiolB/TM > > ------------------------------------------------------------------ --~-> > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > |
