help! safety concern about resetting propane furnaces
10-04-2005, 06:42
Help!
During our last night at the 4th PNW Bird retreat, we developed a low battery. At that point, our propane furnaces ceased to work--or rather, they worked, but there was no heat coming out. Even after the battery had recharged a bit, the furnaces, fans, etc., worked, but there was still no heat. The manual mentions something about a reset procedure. It's kinda scary working with propane. Are there any safety concerns we need to know about in doing this, please? Thanks! Jo-Ski (and Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA [Non-text portions of this message have been removed] |
10-04-2005, 08:25
Problem solved. An archive message about muddaubers in the cold-air return
sparked the idea in Stew to double-check that (we'd had that same problem last summer). Stew discovered a little bit of lint in each blower, causing the blower not to run at the proper speed. Therefore, ignition was not possible. He vacumed around each blower, and now all is working. Thanks! Jo-Ski (and Stew) "The Bird Abides" '83-FC 35 RB Blaine, WA ----- Original Message ----- From: "Jo-Ski" To: Sent: Tuesday, October 04, 2005 11:42 AM Subject: [WanderlodgeForum] help! safety concern about resetting propane furnaces > Help! > > During our last night at the 4th PNW Bird retreat, we developed a low battery. At that point, our propane furnaces ceased to work--or rather, they worked, but there was no heat coming out. Even after the battery had recharged a bit, the furnaces, fans, etc., worked, but there was still no heat. > > The manual mentions something about a reset procedure. It's kinda scary working with propane. Are there any safety concerns we need to know about in doing this, please? > > Thanks! > > Jo-Ski (and Stew) > "The Bird Abides" > '83-FC 35 RB > Blaine, WA > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > |
