Cat fuel filter number needed
11-14-2005, 16:47
I picked up a new primary fuel filter, the filter mounted in the dog
house, but when I installed and ran the motor fuel was leaking out. When I looked at the filter there is a slight difference in the depth of the seal. When I purchased the filter the CAT dealer cross referenced the number and I didn't notice the difference, I should have looked closer because the new filter says "oil filter" on the side. Does anyone with the same year coach have a cat fuel filter part number? Troy Tikalsky 1983 FC33SB Waconia, MN |
