LPG master problem
11-22-2005, 14:45
LPG master problem
None of y'all came looked at our "bird-for-sale" so we're planning a
trip to Arkansas for Thanksgiving to visit Kathy's family. May as well travel in "comfort". Two times I've found you have to work on these "beast" ... when you use'm ... & when they don't get used. My coach batteries were discharged in a very short time last time out ... I found the "coach load - leg two" gauge reading 20 amps (generator panel) while plugged up to shore power with nothing running. Isolated it to the LPG master switch. Amperage draw stops when turning off the LPG Master switch on the monitor panel (above sink) or when pushing the red switch on the LPG "detector" panel located at floor level beside fridge. Does this indicate a problem with solenoid valve in LP line? Is something really pulling 20 amp load (must be hot) or is the reading eronious? How can a 12 volt dc circuit effect readings in the 120 volt ac "leg two" amp meter? Guess you can tell I ain't savey on this part of the coach. I appreciate your assistance as we leave Wednesday afternoon ... don't wanna travel with anything "unsafe". Steve & Kathy Enfinger Newton, GA 91 PT40 WB SideAsile - still for sale |
11-24-2005, 02:11
LPG master problem
Hi Steve:
A couple of questions on this one: 1. Do you see this 20 amp draw when running the gen set? 2. Leg 2 on the gen set panel? not clear on that one. As the amp draw on that panel is DC draw. 3. Is the dc draw ( with the LP master switch on) still there when not on shore power? The leg 2 AC meter is activated from the house type circuit breaker in the main AC power distribution panel. If you have or have access to, an clamp on amp meter, set it to dc amps and clamp around one wire coming from the lp master switch, then on the other wire, this will tell you; 1. which side the problem is on and 2. the actual DC amp draw when the switch is on. I can't think of how the DC circuit is enacting on the AC amp meter on the AC power input and amp draw, unless it is EMF (wires wrapped around or close to, the AC wiring,) going to the meter on the panel. You can get a high amperage draw from a high resistance short. A very common place for this high resistance draw are the DC cables going to the aux bat tie switch which also goes to the hydraulics HWH pump. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:45 AM 11/23/2005 +0000, you wrote: >None of y'all came looked at our "bird-for-sale" so we're planning a >trip to Arkansas for Thanksgiving to visit Kathy's family. May as >well travel in "comfort". > >Two times I've found you have to work on these "beast" ... when you >use'm ... & when they don't get used. My coach batteries were >discharged in a very short time last time out ... I found the "coach >load - leg two" gauge reading 20 amps (generator panel) while >plugged up to shore power with nothing running. Isolated it to the >LPG master switch. Amperage draw stops when turning off the LPG >Master switch on the monitor panel (above sink) or when pushing the >red switch on the LPG "detector" panel located at floor level beside >fridge. > >Does this indicate a problem with solenoid valve in LP line? Is >something really pulling 20 amp load (must be hot) or is the reading >eronious? How can a 12 volt dc circuit effect readings in the 120 >volt ac "leg two" amp meter? Guess you can tell I ain't savey on >this part of the coach. > >I appreciate your assistance as we leave Wednesday afternoon ... >don't wanna travel with anything "unsafe". > >Steve & Kathy Enfinger >Newton, GA >91 PT40 WB SideAsile - still for sale > > > |
