Fuel delivery on 3208 and coolant check questions
03-07-2006, 18:54
Kerry,
One or two hours will not heat the mass of the 3208. I usually turn mine on the night before if we are leaving in the morning. If your fuel system is tight and the batteries and wiring are good it should not be a problem to start. Check the bleed valves. The one time I had a problem starting the valve was not closes tight on the injector pump. We had a emergency last year with my granddaughter and I started mine in -14 with no heat or ether. I do keep additive in the diesel in the winter because we travel to Nebraska and South Dakota. Fresh diesel makes a difference too. I will NOT use ether and removed the ether systems from both the 3208 and the Perkins. I keep a small Honda in one compartment in case I need help getting started. Never had to use it except to make coffee when I did not want the noise of the Perkins. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Tuesday, March 07, 2006 11:13 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Fuel delivery on 3208 and coolant check questions Thanks. It's my first non-glowplug diesel. Engine is a CAT remanf'd. Block heater had been on for about between 1 and 2 hrs. It was probably in the high 30's. Anyone use ether spray systems for cold weather? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > Check SCAs / coolant with test strips, available at CAT or NAPA, get > the ones that test for everything. > > The plexiglass thing sounds like the old water-separator, didn't know > they still installed them in '82, original engine? If air got in, it > wouldn't have started in 3revs, and that's a fairly normal start if > it is cold. The block heater might not work, reach in through the > curbside step in the front bumper and feel for the warm tank heater, > careful, might be hot. Warmth should be felt on top of the air pump > in a few hours. Not quite like the Mercedes, doesn't heat as fast > from the block heater, and doesn't start as fast cold, no glow-plugs. > Warm it up well with the block heater and it should hit on the first > couple of compression strokes if the starter spins it fast enough > (healthy starter, wiring, and batteries). > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Edwards, Kerry" > > > > > > > How is the fuel delivered to the 3208 in an FC? Does it have an > electric fuel pump or a mechanical pump on the engine? I ask because > it took mine about 3 revolutions to fire after sitting overnight and > I think it was short on fuel. If it is an electric pump, where is it > located? I know I have a slight fuel leak where the line comes up to > the back of the engine near the clear plexiglass thingamybob filled > with fuel. I'm guessing it's letting in air. > > > > I've also read somewhere about checking the SCA (?) of the > coolant. Can someone explain what this is and why it is important? > Where does a person obtain the test strips? > > > > Thanks > > > > Kerry > > 82 FC 35 > > Denver > > > > - > > > > > > [Non-text portions of this message have been removed] > > > SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . _____ [Non-text portions of this message have been removed] |
03-08-2006, 02:38
Good morning-
I'm not sure what kind of temperatures you are speaking about, but when bringing my 'bird home from Georgia, it was in the low 20's the night before. The next morning I woke up to begin my trip home it was 27.(the ground was frozen) I just knew that old 3208 CAT would not start-how was I going to get her started in a hotel parking lot- Well, I turned on the key, and waited about 15 sec, and she wired right up, without questioning it. Every time since, she has fired right up.. (keep my fingers crossed) Just my 2 cents Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler Sent: Wednesday, March 08, 2006 1:54 AM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Fuel delivery on 3208 and coolant check questions Kerry, One or two hours will not heat the mass of the 3208. I usually turn mine on the night before if we are leaving in the morning. If your fuel system is tight and the batteries and wiring are good it should not be a problem to start. Check the bleed valves. The one time I had a problem starting the valve was not closes tight on the injector pump. We had a emergency last year with my granddaughter and I started mine in -14 with no heat or ether. I do keep additive in the diesel in the winter because we travel to Nebraska and South Dakota. Fresh diesel makes a difference too. I will NOT use ether and removed the ether systems from both the 3208 and the Perkins. I keep a small Honda in one compartment in case I need help getting started. Never had to use it except to make coffee when I did not want the noise of the Perkins. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ [Non-text portions of this message have been removed] |
03-08-2006, 02:42
Opps- wired right up.. LOL
Fired right up.. _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Stephen Sent: Wednesday, March 08, 2006 9:38 AM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Fuel delivery on 3208 and coolant check questions Good morning- I'm not sure what kind of temperatures you are speaking about, but when bringing my 'bird home from Georgia, it was in the low 20's the night before. The next morning I woke up to begin my trip home it was 27.(the ground was frozen) I just knew that old 3208 CAT would not start-how was I going to get her started in a hotel parking lot- Well, I turned on the key, and waited about 15 sec, and she wired right up, without questioning it. Every time since, she has fired right up.. (keep my fingers crossed) Just my 2 cents Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler Sent: Wednesday, March 08, 2006 1:54 AM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Fuel delivery on 3208 and coolant check questions Kerry, One or two hours will not heat the mass of the 3208. I usually turn mine on the night before if we are leaving in the morning. If your fuel system is tight and the batteries and wiring are good it should not be a problem to start. Check the bleed valves. The one time I had a problem starting the valve was not closes tight on the injector pump. We had a emergency last year with my granddaughter and I started mine in -14 with no heat or ether. I do keep additive in the diesel in the winter because we travel to Nebraska and South Dakota. Fresh diesel makes a difference too. I will NOT use ether and removed the ether systems from both the 3208 and the Perkins. I keep a small Honda in one compartment in case I need help getting started. Never had to use it except to make coffee when I did not want the noise of the Perkins. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ [Non-text portions of this message have been removed] SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
03-08-2006, 03:26
I wasn't thinking of using ether above zero, but in extreme
circumstances. I had my MB out a few weeks ago at 35 below and it wouldn't start. It has no block heater. I wouldn't use ether on an indirect injection diesel but it was my understanding it did no harm on direct injection diesels. I used to operate a 1937 NorthWest crane, and it was never started without ether. Considering the fact that both the engine and generators are diesels and we wild camp a lot, plugging in the diesels to start at low temperatures is not always an option. So, I just want to develop skills at low temperature starting. I can usually start my MB's with no block heaters down to about 10 below without a problem. Kerry 82 FC35 Denver |
03-08-2006, 04:17
Kerry your Kohler generator should have glow plugs.mine does. Start
the generator and then let it both charge up your starting batteries (same as the house batteries) and then on the block heater. It should start up within an hour maybe less. I have had no problem at all starting my 3208NA in cold weather even when it got down close to 10 degrees. You have to have good compression and have it timed right however. Remember the Mb has glow plugs so you need a good strong battery to both power the glo plugs and then turn the engine over fast enough to fire. I would not use ether in my Cat 3208NA even though I know it has been done. If it should fire prematurely there is the possibility of bent rods and worse. Tom Warner 1982 FC35 Vernon Center,NY At 10:26 AM 3/8/2006, you wrote: >I wasn't thinking of using ether above zero, but in extreme >circumstances. I had my MB out a few weeks ago at 35 below and it >wouldn't start. It has no block heater. I wouldn't use ether on an >indirect injection diesel but it was my understanding it did no harm >on direct injection diesels. I used to operate a 1937 NorthWest >crane, and it was never started without ether. >Considering the fact that both the engine and generators are diesels >and we wild camp a lot, plugging in the diesels to start at low >temperatures is not always an option. So, I just want to develop >skills at low temperature starting. I can usually start my MB's with >no block heaters down to about 10 below without a problem. > >Kerry >82 FC35 >Denver > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
