Microphor toilet
03-16-2006, 11:56
Microphor toilet
Folks,
There's an air valve under the sink in my bathroom that seems to be leaking. The valve is part of the control for the microphor toilet. The valve has an input and an output a pinhole and an adjustment thumb wheel. Air seems to constantly leak from the pinhole. When I ,the air leak for the pinhole stops, after flushing is complete leaking resumes. The valve seems to be some sort of pressure regulator/bleed off valve. Any idea what it does, how it should work, and where I might find a replacement (if indeed a steady bleeding of air is abnormal)? TIA, David Brady '02 LXi, Smokey, Va |
03-16-2006, 12:50
Microphor toilet
Thanks George, I'll give Lee at Microphor a call
in the morning. David Brady '02 LXi, Smokey, Va George Lowry wrote: > David, > > Contact Microphor at <http://www.microphor.com> IIRC the guy you want to > talk to is Lee. They give excellent support. Good excuse for a trip > to the west coast to visit the factory. You should have a manual > which describes all the parts, etc. If not, you can get it from > Microphor. > > George Lowry > '06 Alpine Apex - Formerly '95 WBDA 4203 > Spearfish, SD - now at TTN Las Vegas > > > David Brady wrote: > > >> Folks, >> >> There's an air valve under the sink in my >> bathroom that seems to be leaking. The >> valve is part of the control for the microphor >> toilet. The valve has an input and an output >> a pinhole and an adjustment thumb wheel. >> Air seems to constantly leak from the pinhole. >> When I ,the air leak for the pinhole >> stops, after flushing is complete leaking >> resumes. The valve seems to be some >> sort of pressure regulator/bleed off valve. >> Any idea what it does, how it should work, >> and where I might find a replacement (if >> indeed a steady bleeding of air is abnormal)? >> >> TIA, >> David Brady >> '02 LXi, Smokey, >> Va >> >> >> >> Yahoo! Groups Links >> >> >> >> >> >> >> >> >> > > > > Yahoo! Groups Links > > > > > > > > > |
03-26-2006, 14:33
Microphor toilet
David,
Contact Microphor at <http://www.microphor.com> IIRC the guy you want to talk to is Lee. They give excellent support. Good excuse for a trip to the west coast to visit the factory. You should have a manual which describes all the parts, etc. If not, you can get it from Microphor. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - now at TTN Las Vegas David Brady wrote: > Folks, > > There's an air valve under the sink in my > bathroom that seems to be leaking. The > valve is part of the control for the microphor > toilet. The valve has an input and an output > a pinhole and an adjustment thumb wheel. > Air seems to constantly leak from the pinhole. > When I ,the air leak for the pinhole > stops, after flushing is complete leaking > resumes. The valve seems to be some > sort of pressure regulator/bleed off valve. > Any idea what it does, how it should work, > and where I might find a replacement (if > indeed a steady bleeding of air is abnormal)? > > TIA, > David Brady > '02 LXi, Smokey, > Va > > > > Yahoo! Groups Links > > > > > > > > |
03-26-2006, 15:41
Microphor toilet
BTW, David,
Both of your posts came thru with an old date on them. Recommend that you check the date on your computer. George Lowry David Brady wrote: > Thanks George, I'll give Lee at Microphor a call > in the morning. > > David Brady > '02 LXi, Smokey, > Va > > > George Lowry wrote: > >>David, >> >>Contact Microphor at <http://www.microphor.com> IIRC the guy you want to >>talk to is Lee. They give excellent support. Good excuse for a trip >>to the west coast to visit the factory. You should have a manual >>which describes all the parts, etc. If not, you can get it from >>Microphor. >> >>George Lowry >>'06 Alpine Apex - Formerly '95 WBDA 4203 >>Spearfish, SD - now at TTN Las Vegas >> >> >>David Brady wrote: >> >> >> >>>Folks, >>> >>>There's an air valve under the sink in my >>>bathroom that seems to be leaking. The >>>valve is part of the control for the microphor >>>toilet. The valve has an input and an output >>>a pinhole and an adjustment thumb wheel. >>>Air seems to constantly leak from the pinhole. >>>When I ,the air leak for the pinhole >>>stops, after flushing is complete leaking >>>resumes. The valve seems to be some >>>sort of pressure regulator/bleed off valve. >>>Any idea what it does, how it should work, >>>and where I might find a replacement (if >>>indeed a steady bleeding of air is abnormal)? >>> >>>TIA, >>>David Brady >>>'02 LXi, Smokey, >>>Va >>> >>> >>> >>>Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> > > > > > > Yahoo! Groups Links > > > > > > > > > |
03-30-2006, 06:44
Microphor toilet
There is an air regulator that fits between the 12v toilet
air compressor and the toilet flush handle. The part is made by Clippard and is blue-bird part number: 3824745. This part was leaking causing my air compressor to be on approx. 15% of the time. I installed a new regulator and all is well again. David Brady, '02 LXi, Smokey, Va David Brady wrote: > Folks, > > There's an air valve under the sink in my > bathroom that seems to be leaking. The > valve is part of the control for the microphor > toilet. The valve has an input and an output > a pinhole and an adjustment thumb wheel. > Air seems to constantly leak from the pinhole. > When I ,the air leak for the pinhole > stops, after flushing is complete leaking > resumes. The valve seems to be some > sort of pressure regulator/bleed off valve. > Any idea what it does, how it should work, > and where I might find a replacement (if > indeed a steady bleeding of air is abnormal)? > > TIA, > David Brady > '02 LXi, Smokey, > Va > > > > Yahoo! Groups Links > > > > > > > > |
