Vlv last adjustment
03-26-2006, 08:08
Vlv last adjustment
Well today I finally got under the old bird and looked around to see
that timing mark that's on the crank shaft and yes it there and I can
see the pointer also but it might just take an inspection mirror to see
that its in the proper position for vlv timing. Now has anyone ever
here taken oft there vlv covers with the front end still on? It looks
to like it can be done this was from the top but it will require a
little bit of bending and knuckle busting. This afternoon I'm going to
look under the dog house to see just how much room there is in there to
do this operation. Again has anyone ever done this procedure before
without taking out the radiator? Thanks
Jon
Rebel Bird
Bremerton Washington
03-26-2006, 09:16
Vlv last adjustment
I don't see how taking off the radiator will give any more access to
the valve covers. Removing the bottom part of the doghouse should
give better access to the lower valve cover bolts, although they may
be more accessible from below. You could do the job without looking
at the timing mark if you look closely at the valves themselves and
adjust the ones with no pressure on them. I think the only reason to
use the timing mark is to follow the sequence specified by CAT as to
which valves are not under pressure at specific points in the cycle.
Kerry
82 FC 35
Denver
> Jon
> Rebel Bird
03-26-2006, 09:47
Vlv last adjustment
> Kerry
> 82 FC 35
> Denver
see
can
to see
ever
looks
a
going to
there to
before
> > Jon
> > Rebel Bird
First of all Kerry your right about those covers. Just went out and
took a look at how they fit down there in the obelisk. Now I wonder
how do you take the dog house oft from the body of the coach. Looks
like that bottom part of dog house is bolted or screwed on someway.
But I have a rug in the way and really don't know what to expect
underneath that material.
03-26-2006, 10:09
Vlv last adjustment
You unbolt the hinges from the top cover, and unbolt the brace and the
top cover comes off. There are bolts going down into the floor around
the lower section (there may also be some going forward into the
'firewall'Wink then you lift up the lower section and remove it. The
carpet should move enough to access the bolts. It's shown in the
owner's manual.
Kerry
82 FC35
Denver --
03-26-2006, 13:36
Vlv last adjustment
around
> owner's manual.
> Kerry
> 82 FC35
> Denver --
wonder
Looks
someway.
Thanks Kerry!!!! And now to go out to the bird and get that repair
book.
Jon
1978 Wanderlodge
Brmerton Washington
03-26-2006, 14:21
Vlv last adjustment
> the
> around
> > owner's manual.
> > Kerry
> > 82 FC35
> > Denver --
> and
> wonder
> Looks
> someway.
expect
> book.
> Jon
> 1978 Wanderlodge
> Brmerton Washington
Oops no picture of dog house in my repair book, could someone E-mail
me a photo copy of this area. I know I can go at it blindly but it
sure would be nice to have a sketch or something to check out that
bolt pattern that hold the bottom of the dog house down.
Jon Lecich
Rebel Bird
03-26-2006, 15:08
Vlv last adjustment
Detailed instructions on doghouse removal under 'files' at the Yahoo
FC_Wanderlodge site.
Kerry
03-26-2006, 17:46
Vlv last adjustment
> Kerry
Thanks Kerry I will check out my rig with the instruction and let
this site know how it come along. I might just take oft the dog house
and the transition piece and have my friend do the vlv adjustment.
By meaning friend that is the shop and personnel who work on the
Rebel Bird in the past. I think the big part of this job is just
getting that dog house oft and the vlv covers ready to remove for
inspection. The inspection shouldn't take more than one hour and say
an hour to remove and install the vlv cover. The reason I'm thinking
about letting Don my mechanic do it as he has a big shop and is
familiar with 3208's.
Oh just a plug for his shop as he has done great work for me in the
past And is very safety conscious and back up his work with a full
six month
guarantee or six thousand miles which ever come first. The name of
his business is Nor-Star Inc. and is based in
Bremerton Washington and charges $75 and hour for RV repair.
Jon
Jipjob@...
