Where to get fresh water tank?
04-03-2006, 09:16
Well I finally figured out that my fresh water tank has a large hole
in it ( a very large hole) where can I find a replacement? Thanks Mike 80FC33 Taylor Mill,Ky |
04-03-2006, 09:38
If it's plastic, most likely HDPE, you can fix....if not, you can make your
own using the above material...Blair At 02:16 PM 4/3/2006, you wrote: >Well I finally figured out that my fresh water tank has a large hole >in it ( a very large hole) where can I find a replacement? > >Thanks > >Mike >80FC33 >Taylor Mill,Ky > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- [Non-text portions of this message have been removed] |
04-03-2006, 11:07
get a plastic repair kit and repair it in place. I have a leister
Triac heat gun to do it but there are lots of other ways to repair it. http://www.heatgunkit.com/new.php?id=17 http://www.pplmotorhomes.com/parts/caulk...r-kits.htm Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT40 At 05:16 PM 4/3/2006, you wrote: >Well I finally figured out that my fresh water tank has a large hole >in it ( a very large hole) where can I find a replacement? > >Thanks > >Mike >80FC33 >Taylor Mill,Ky > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-03-2006, 12:04
Thanks Tom-
I will try the repair kit. Any advice in removing the tank? --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > get a plastic repair kit and repair it in place. I have a leister > Triac heat gun to do it but there are lots of other ways to repair it. > http://www.heatgunkit.com/new.php?id=17 > > http://www.pplmotorhomes.com/parts/caulk...r-kits.htm > > > > Tom Warner > Vernon Center,NY > 1982 FC35 (for sale soon) > 1985 PT40 > > At 05:16 PM 4/3/2006, you wrote: > >Well I finally figured out that my fresh water tank has a large hole > >in it ( a very large hole) where can I find a replacement? > > > >Thanks > > > >Mike > >80FC33 > >Taylor Mill,Ky > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
04-03-2006, 14:04
Plastic welding is not that difficult and sure to be cheaper than a
new tank. I've fixed many a broken waste tank with epoxy. I'd consider both those options before replacement. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Blair > > If it's plastic, most likely HDPE, you can fix....if not, you can make your > own using the above material...Blair > > |
04-03-2006, 14:55
Why remove the tank unless it is in a position you cant get to? The
less you move the less work it will be. Some of the water tanks are an unusual shape and not that easy to remove. Just a suggestion but if the break or hole is 3" or less and on the top of the tank why not make an inspection port out of it? You can buy the kits from West Marine. Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT40 At 08:04 PM 4/3/2006, you wrote: >Thanks Tom- >I will try the repair kit. Any advice in removing the tank? > > > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > > > get a plastic repair kit and repair it in place. I have a leister > > Triac heat gun to do it but there are lots of other ways to repair >it. > > > <http://www.heatgunkit.com/new.php?id=17>http://www.heatgunkit.com/new.php?id=17 > > > > http://www.pplmotorhomes.com/parts/caulk...r-kits.htm > > > > > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 (for sale soon) > > 1985 PT40 > > > > At 05:16 PM 4/3/2006, you wrote: > > >Well I finally figured out that my fresh water tank has a large >hole > > >in it ( a very large hole) where can I find a replacement? > > > > > >Thanks > > > > > >Mike > > >80FC33 > > >Taylor Mill,Ky > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > > > > >---------- > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
