Hydraulic leveler Drive 90 SP36
04-02-2006, 01:47
Help,
My bird has been stored all winter with the jacks down and now the leveler motor runs all the time (unless I shut off the level minder). There is plenty of fluid in the reservoir and the jacks still extend and retract, however the green indicators now only work for the right side jacks. With the engine running when I turn on the level minder the alt charge indicator goes up to about 75 amps from it's normal 5-10. I did notice that the left rear jack takes a long time to retract the last several inches. Chuck Harrison 90 SP36 Akron, Ohio |
04-02-2006, 02:22
What type control panel? Manual or solid state?
MH ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 02, 2006 8:47 AM Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 Help, My bird has been stored all winter with the jacks down and now the leveler motor runs all the time (unless I shut off the level minder). There is plenty of fluid in the reservoir and the jacks still extend and retract, however the green indicators now only work for the right side jacks. With the engine running when I turn on the level minder the alt charge indicator goes up to about 75 amps from it's normal 5-10. I did notice that the left rear jack takes a long time to retract the last several inches. Chuck Harrison 90 SP36 Akron, Ohio SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-02-2006, 03:09
Manual- 4 individual levers.
--- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > What type control panel? Manual or solid state? > MH > ----- Original Message ----- > From: williamcharrison > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 02, 2006 8:47 AM > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > Help, > My bird has been stored all winter with the jacks down > and now the leveler motor runs all the time (unless I shut off the > level minder). There is plenty of fluid in the reservoir and the > jacks still extend and retract, however the green indicators now only > work for the right side jacks. With the engine running when I turn on > the level minder the alt charge indicator goes up to about 75 amps > from it's normal 5-10. I did notice that the left rear jack takes a > long time to retract the last several inches. > > Chuck Harrison > 90 SP36 > Akron, Ohio > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
04-02-2006, 06:06
Is there any other ram the leveler pump powers other than the jacks?
like gen slide? Greg --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Manual- 4 individual levers. > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > What type control panel? Manual or solid state? > > MH > > ----- Original Message ----- > > From: williamcharrison > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 02, 2006 8:47 AM > > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > > > > Help, > > My bird has been stored all winter with the jacks down > > and now the leveler motor runs all the time (unless I shut off > the > > level minder). There is plenty of fluid in the reservoir and the > > jacks still extend and retract, however the green indicators now > only > > work for the right side jacks. With the engine running when I > turn on > > the level minder the alt charge indicator goes up to about 75 > amps > > from it's normal 5-10. I did notice that the left rear jack > takes a > > long time to retract the last several inches. > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > ------------------------------------------------------------------ - > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ------------------------------------------------------------------ - > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
04-02-2006, 07:23
There is a micro switch that runs the motor, mounted on the forward side of the
valve body, under the cover. I'd check it for function. Motor should only run when levers are moved to the extend position. There is a little wire fence that contacts the levers to close the switch for extending jacks. Slow retraction is sticky jack, lever not moving enough to uncover vent port or debris in oil causing blockage. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 02, 2006 10:09 AM Subject: [WanderlodgeForum] Re: Hydraulic leveler Drive 90 SP36 Manual- 4 individual levers. --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > What type control panel? Manual or solid state? > MH > ----- Original Message ----- > From: williamcharrison > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 02, 2006 8:47 AM > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > Help, > My bird has been stored all winter with the jacks down > and now the leveler motor runs all the time (unless I shut off the > level minder). There is plenty of fluid in the reservoir and the > jacks still extend and retract, however the green indicators now only > work for the right side jacks. With the engine running when I turn on > the level minder the alt charge indicator goes up to about 75 amps > from it's normal 5-10. I did notice that the left rear jack takes a > long time to retract the last several inches. > > Chuck Harrison > 90 SP36 > Akron, Ohio > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-02-2006, 08:30
Thanks Mike,
I just returned from the bird having cycled the jacks several times, now only the right front green indicator light stays on when the bags are filled and the jacks are all up and the levers are in "neutral". I looked under the coach and I see only 1 level switch assembly in the front near the center of the coach but actuated by a rod attached closer to the left front wheel. The cover you mention, is this under the step? . --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > There is a micro switch that runs the motor, mounted on the forward side of the valve body, under the cover. I'd check it for function. Motor should only run when levers are moved to the extend position. There is a little wire fence that contacts the levers to close the switch for extending jacks. > Slow retraction is sticky jack, lever not moving enough to uncover vent port or debris in oil causing blockage. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: williamcharrison > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 02, 2006 10:09 AM > Subject: [WanderlodgeForum] Re: Hydraulic leveler Drive 90 SP36 > > > Manual- 4 individual levers. > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > What type control panel? Manual or solid state? > > MH > > ----- Original Message ----- > > From: williamcharrison > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 02, 2006 8:47 AM > > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > > > > Help, > > My bird has been stored all winter with the jacks down > > and now the leveler motor runs all the time (unless I shut off > the > > level minder). There is plenty of fluid in the reservoir and the > > jacks still extend and retract, however the green indicators now > only > > work for the right side jacks. With the engine running when I > turn on > > the level minder the alt charge indicator goes up to about 75 > amps > > from it's normal 5-10. I did notice that the left rear jack > takes a > > long time to retract the last several inches. > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
04-02-2006, 08:35
It's the decorative cover over the control valve body, the levers stick through
it. It's not fun to access that stuff. MH ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 02, 2006 3:30 PM Subject: [WanderlodgeForum] Re: Hydraulic leveler Drive 90 SP36 Thanks Mike, I just returned from the bird having cycled the jacks several times, now only the right front green indicator light stays on when the bags are filled and the jacks are all up and the levers are in "neutral". I looked under the coach and I see only 1 level switch assembly in the front near the center of the coach but actuated by a rod attached closer to the left front wheel. The cover you mention, is this under the step? . --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > There is a micro switch that runs the motor, mounted on the forward side of the valve body, under the cover. I'd check it for function. Motor should only run when levers are moved to the extend position. There is a little wire fence that contacts the levers to close the switch for extending jacks. > Slow retraction is sticky jack, lever not moving enough to uncover vent port or debris in oil causing blockage. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: williamcharrison > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 02, 2006 10:09 AM > Subject: [WanderlodgeForum] Re: Hydraulic leveler Drive 90 SP36 > > > Manual- 4 individual levers. > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > What type control panel? Manual or solid state? > > MH > > ----- Original Message ----- > > From: williamcharrison > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 02, 2006 8:47 AM > > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > > > > Help, > > My bird has been stored all winter with the jacks down > > and now the leveler motor runs all the time (unless I shut off > the > > level minder). There is plenty of fluid in the reservoir and the > > jacks still extend and retract, however the green indicators now > only > > work for the right side jacks. With the engine running when I > turn on > > the level minder the alt charge indicator goes up to about 75 > amps > > from it's normal 5-10. I did notice that the left rear jack > takes a > > long time to retract the last several inches. > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > > > > --------------------------------------------------------------- ---- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > --------------------------------------------------------------- ---- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-02-2006, 10:35
The lights on the levelors have nothing to do with the hydraulic
motor extending or retracting the jacks. If any one of the four jack levers are put in the extend position the hydraulic motor should come on and extend that jack. I am not familiar with the colors of the 8 LEDS on your coach but mine are red for a jack extended and blue for a jack to low and needs to be extended more. If all of the jacks are down then all of the red LEDs will be on. At the same time the low corner of the coach will cause the blue LED to come on. I believe your SP36 generator uses the same hydraulic motor to power the slide. I know my 1985 PT40 generator works off the same hydraulic motor. tom warner Vernon Center,NY PM 4/2/2006, you wrote: >Thanks Mike, > I just returned from the bird having cycled the jacks several >times, now only the right front green indicator light stays on >when the bags are filled and the jacks are all up and the levers >are in "neutral". I looked under the coach and I see only 1 level >switch assembly in the front near the center of the coach but >actuated by a rod attached closer to the left front wheel. The >cover you mention, is this under the step? > >. --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" ><MHOHNSTEIN@...> wrote: > > > > There is a micro switch that runs the motor, mounted on the >forward side of the valve body, under the cover. I'd check it for >function. Motor should only run when levers are moved to the extend >position. There is a little wire fence that contacts the levers to >close the switch for extending jacks. > > Slow retraction is sticky jack, lever not moving enough to uncover >vent port or debris in oil causing blockage. > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > ----- Original Message ----- > > From: williamcharrison > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, April 02, 2006 10:09 AM > > Subject: [WanderlodgeForum] Re: Hydraulic leveler Drive 90 SP36 > > > > > > Manual- 4 individual levers. > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > <MHOHNSTEIN@> wrote: > > > > > > What type control panel? Manual or solid state? > > > MH > > > ----- Original Message ----- > > > From: williamcharrison > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 02, 2006 8:47 AM > > > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > > > > > > > Help, > > > My bird has been stored all winter with the jacks down > > > and now the leveler motor runs all the time (unless I shut >off > > the > > > level minder). There is plenty of fluid in the reservoir >and the > > > jacks still extend and retract, however the green indicators >now > > only > > > work for the right side jacks. With the engine running when >I > > turn on > > > the level minder the alt charge indicator goes up to about >75 > > amps > > > from it's normal 5-10. I did notice that the left rear jack > > takes a > > > long time to retract the last several inches. > > > > > > Chuck Harrison > > > 90 SP36 > > > Akron, Ohio > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge >Automotive > > maintenance > > > Recreational vehicle dealer Used recreational >vehicles > > Automotive radiators > > > > > > > > > --------------------------------------------------------------- >---- > > ----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! >Terms > > of Service. > > > > > > > > > --------------------------------------------------------------- >---- > > ----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive >maintenance > > Recreational vehicle dealer Used recreational vehicles >Automotive radiators > > > > > > ------------------------------------------------------------------- >----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms >of Service. > > > > > > ------------------------------------------------------------------- >----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-02-2006, 13:45
Maybe the prob is with the gen-set slide switch or valve??
Greg I believe > your SP36 generator uses the same hydraulic motor to power the slide. > I know my 1985 PT40 generator works off the same hydraulic motor. > > tom warner > Vernon Center,NY |
04-03-2006, 01:12
Only the jacks.
--- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Is there any other ram the leveler pump powers other than the jacks? > like gen slide? > Greg > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > Manual- 4 individual levers. > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > <MHOHNSTEIN@> wrote: > > > > > > What type control panel? Manual or solid state? > > > MH > > > ----- Original Message ----- > > > From: williamcharrison > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 02, 2006 8:47 AM > > > Subject: [WanderlodgeForum] Hydraulic leveler Drive 90 SP36 > > > > > > > > > Help, > > > My bird has been stored all winter with the jacks down > > > and now the leveler motor runs all the time (unless I shut off > > the > > > level minder). There is plenty of fluid in the reservoir and > the > > > jacks still extend and retract, however the green indicators > now > > only > > > work for the right side jacks. With the engine running when I > > turn on > > > the level minder the alt charge indicator goes up to about 75 > > amps > > > from it's normal 5-10. I did notice that the left rear jack > > takes a > > > long time to retract the last several inches. > > > > > > Chuck Harrison > > > 90 SP36 > > > Akron, Ohio > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > > maintenance > > > Recreational vehicle dealer Used recreational vehicles > > Automotive radiators > > > > > > > > > --------------------------------------------------------------- --- > - > > ----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > > > > > --------------------------------------------------------------- --- > - > > ----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
