Thin lites
04-08-2006, 08:50
Thin lites
I have removed my bath thin lite and was going to replace the ballast.
Low and behold there is a circuit board on the back of that thing. That
is the culprit that is fried. Anyone replace this circuit board? why
would there be a circuit board on a flourescent fixture? Inquiring non
electrical mind wants to know. Ernie-83pt40 in Louisiana
04-08-2006, 12:04
Thin lites
Those lights are actually 110V florescent lights. The circuit board is
the inverter.
I have replaced those. They run about $35 ea.
After the Zab Juda/Mayweather fight, I'll see if I can find where to
buy and the part#.
Jay Darst
85PT40
Springfield, IL
ballast.
That
non
04-08-2006, 12:14
Thin lites
Contact Stephen Birtles. He most likely has what you need or can get
them for you.
> the inverter.
> buy and the part#.
04-08-2006, 13:43
Thin lites
Hi Ernie,
Check out <http://www.thinlite.com> They have a flat rate repair on their units
that is, IIRC $23.50 and you get the same warranty as a new lite. I had a
couple of mine done and they were great.
George Lowry
'06 Alpine Alpex - Formerly '95 WBDA 4203
Spearfish, SD Now in Columbia, CA
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Ernest Ekberg
Sent: Saturday, April 08, 2006 1:50 PM
Subject: [WanderlodgeForum] Thin lites
Yahoo! Groups Links
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.3.5/303 - Release Date: 4/6/2006
04-09-2006, 04:55
Thin lites
Thanks, Jay. I bought those inverter/ballasts from Stephen Birtles last
year. I was not expecting a "strip' ballast.Stephen called me and directed me
through the process. ernie-83pt40- coach in louisiana, me home in texas
04-09-2006, 07:58
Thin lites
We now have the replacement ballasts for twin tubes lights. These
ballasts are a higher quality than thin lite and bolt or rivet into
the same place as the original ballast. They come in two power
capacities up to 8 watt twin tube or 16 wattts total and up to 15
watt twin tube or 30 watts total. They are voltage stable between 9and
16 volts and will survuve temporary surges to 24 volts although not
recommended
We are also going to offer a rebuild service for 12 volt flourescent
lights and it is very competitively priced with other sources in the
industry
Stephen 77fc35
> the inverter.
> buy and the part#.
> Jay Darst
> 85PT40
> Springfield, IL
> ballast.
> That
> non
