Air Brakes - Drain Sound
04-06-2006, 01:39
I noticed that most other 'birds air brakes make that "pssshhh' air
release sound every few seconds while idling. Mine does not. I went under the old bird, and found a "Bendix" device under my wet tank. I removed it, disassembled it, and cleaned well, and re-assembled it. I have yet to try starting the old bird to see if this fixed it. (radiator out being soldered) Is this the device that does that? On the unit it says "push pin to manually drain" Also do you know if there is a air drier? If so, where would it be located? I would like to change the filters, ect. Thank you Stephen 81 FC-33SB Plant City, FL |
04-07-2006, 12:40
Stephen,
My 81FC31 did not have an air dryer. I did however add a spitter valve to the bottom of the service air tank. It sounds like someone has added a spitter valve to yours. It comes on when the compressor starts and again when the compressor stops. All 3 air tanks had pull wires to manually drain the water build-up. Dick Hayden - '87 PT 38 - Lk Stevens, WA ----- Original Message ----- From: Stephen H To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 06, 2006 6:39 AM Subject: [WanderlodgeForum] Air Brakes - Drain Sound I noticed that most other 'birds air brakes make that "pssshhh' air release sound every few seconds while idling. Mine does not. I went under the old bird, and found a "Bendix" device under my wet tank. I removed it, disassembled it, and cleaned well, and re-assembled it. I have yet to try starting the old bird to see if this fixed it. (radiator out being soldered) Is this the device that does that? On the unit it says "push pin to manually drain" Also do you know if there is a air drier? If so, where would it be located? I would like to change the filters, ect. Thank you Stephen 81 FC-33SB Plant City, FL SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKk\ U7Dzhn_ObWmSYTw> Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ> Automotive maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\ u_5wI8Pmy34cC1O9CxA> Recreational vehicle dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\ XahaeYHfELr6o72IW1A> Used recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\ ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UG\ EY5km4L-kXbDI4ZSadEw> Automotive radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\ SsCWgTnMq_4GlXA> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-08-2006, 15:04
Thank you all for your info and everyone who responded.
I have learned that the device responsible for that noise is an Air Dryer, which I do not have. I will look into getting one- although the system has worked well all this time without it- However with age of everything, I feel that it wouldn't hurt. I will look for one reasonably priced- A Bendix AD-9. Stephen 81 FC-33SB Plant City, FL Finally rain on its way tonight!!! 1st rain in 45+ days! _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Richard Hayden Sent: Friday, April 07, 2006 8:40 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Air Brakes - Drain Sound Stephen, My 81FC31 did not have an air dryer. I did however add a spitter valve to the bottom of the service air tank. It sounds like someone has added a spitter valve to yours. It comes on when the compressor starts and again when the compressor stops. All 3 air tanks had pull wires to manually drain the water build-up. Dick Hayden - '87 PT 38 - Lk Stevens, WA ----- Original Message ----- From: Stephen H To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 06, 2006 6:39 AM Subject: [WanderlodgeForum] Air Brakes - Drain Sound I noticed that most other 'birds air brakes make that "pssshhh' air release sound every few seconds while idling. Mine does not. I went under the old bird, and found a "Bendix" device under my wet tank. I removed it, disassembled it, and cleaned well, and re-assembled it. I have yet to try starting the old bird to see if this fixed it. (radiator out being soldered) Is this the device that does that? On the unit it says "push pin to manually drain" Also do you know if there is a air drier? If so, where would it be located? I would like to change the filters, ect. Thank you Stephen 81 FC-33SB Plant City, FL SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw> Wanderlodge<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance& Recreational vehicle dealer<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A> Used recreational vehicles<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehi ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
