7 way trailer plug
04-20-2006, 07:50
7 way trailer plug
Bruce- i have the plastic plug and it works just fine. Ernie -83pt40 in
louisiana [Non-text portions of this message have been removed] |
04-20-2006, 11:42
7 way trailer plug
All of the BB's I have looked at use a metal 7 way plug on the rear.
Does that interchange with the male 7 way PLASTIC plug that is commonly used? (Bargman, pollack,etc.) Bruce maybe soon |
04-20-2006, 11:49
7 way trailer plug
Bruce,
It is a standard "RV Style" plug that is one most everything these days. It doesn't care if the plug end is the new plastic style or the old metal ones. Mike Bulriss 1991 WB40 "Texas Minivan" Samn Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > All of the BB's I have looked at use a metal 7 way plug on the rear. > Does that interchange with the male 7 way PLASTIC plug that is commonly > used? (Bargman, pollack,etc.) > > Bruce maybe soon > |
04-20-2006, 14:23
7 way trailer plug
Yes but it (originally) doesn't match the standard Bargman pin-out
(wiring). I keep a couple of "blue-bird adapters" around, a short extension made up to change pinout to standard, for pulling my car- hauler etc. You can also re-wire it as I have a couple of my coaches, but it's not necessary. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > All of the BB's I have looked at use a metal 7 way plug on the rear. > Does that interchange with the male 7 way PLASTIC plug that is commonly > used? (Bargman, pollack,etc.) > > Bruce maybe soon > |
04-20-2006, 16:26
7 way trailer plug
Ernie & Mike: Thank you.
Bruce |
