Shock Adjustment?
04-25-2006, 13:26
Shock Adjustment?
We are putting new shocks on this weekend, the fronts are adjustable.
Where is a good place to start with settings,would be nice to get them close on the first try. Thankyou! Jeff and Michelle August 1980FC35RB Plymouth Wi. |
04-25-2006, 14:14
Shock Adjustment?
If you are using Koni shocks, I went with full stiff then backed off one
click. dandarst86fc35rbhuntleyil. @roadamerica this weekend. >From: "Jeff August" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Shock Adjustment? >Date: Wed, 26 Apr 2006 01:26:52 -0000 > >We are putting new shocks on this weekend, the fronts are adjustable. >Where is a good place to start with settings,would be nice to get them >close on the first try. >Thankyou! >Jeff and Michelle August >1980FC35RB >Plymouth Wi. > > > > |
04-25-2006, 15:01
Shock Adjustment?
Dan,
Your shocks had clicks? Mine had a rotational adjustment that was infinite(no clicks), we counted 1/2 turns. Adjusted to 1/2 turn from full firm. In total, there were 1.75 turns from most rebound control to least control. have fun at LBL! I'm going to the top fuel Harley Drags in St.louis next weekend, May 6 & 7. Next time... Jay --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > > If you are using Koni shocks, I went with full stiff then backed off one > click. > > dandarst86fc35rbhuntleyil. @roadamerica this weekend. > > > >From: "Jeff August" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Shock Adjustment? > >Date: Wed, 26 Apr 2006 01:26:52 -0000 > > > >We are putting new shocks on this weekend, the fronts are adjustable. > >Where is a good place to start with settings,would be nice to get them > >close on the first try. > >Thankyou! > >Jeff and Michelle August > >1980FC35RB > >Plymouth Wi. > > > > > > > > > |
