88 power problem update
02-11-2007, 12:44
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote:
Arriving at Quartszite for the rally a cuppala weeks ago I fired off
genny and found I had lost AC power to the house. It was working when
I left. Applying forum knowledge, I checked the fuses and breakers on
genny. Without success, I came to the conclusion I'd lost the master
switch next to the passenger seat. As a last resort (shuda been the
first), I went into the closet housing the main breaker box and found
that the last thing I did before leaving was to push clothes on
hangers onto the clothes rack inadvertently turning off the master
breaker. Whodathunkit?
Add item: Close break box door in closet after use
Ron, No. California
85PT36
> Leroy,
> That's not a bad little check list even if you if you don't think you
> are experiencing a power failure. In the fog and confusion of an "Oh,
> crap" moment, it is all too easy to overlook the basics.
02-11-2007, 15:27
Thank you so much. Mine is in the same place. I will place it on the list.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Sunday, February 11, 2007 6:44 PM
Subject: [WanderlodgeForum] Re: 88 power problem update
Ron, No. California
85PT36
> Leroy,
