Engine belts 90SP36
07-23-2006, 07:33
Engine belts 90SP36
Can someone give me the specs or part numbers for all the engine
belts. Last trip the engine started to overheat about 20 miles from home and i found that both fan belts and both alternator/air pump belts were extremely loose. One oddity is that in both cases one belt was much looser than the other. I have tightened them all but am out of room to tighten the alt. belts any more. Chuck Harrison Akron, Ohio 90WLSP36 |
