Solenoid between the chassis batteries and the generator battery
08-04-2006, 13:05
I would think the relays for the start Genset functions should run
off the gen battery only and any cross hooking could cause a path around the diode and a failure to remotly start if house, coach batteries are dead. Gregory O'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, TeamConfuzed@... wrote: > > << I believe '83 on the PT > > and '87 on the FC? Prior to this system the FCs used a "battery > > isolator" located just rearward of the house batteries (started > > around '82). >> > > > Ours is an '82 PT ... one of the first PT's made. So what's causing the > batteries to stay connected, and where's it at? > > --PirateJohn-- > > http://www.PirateJohn.com > Directeur Sportif, TeamConfuzed > > > [Non-text portions of this message have been removed] > |
08-04-2006, 13:50
Greg:
The idea of the battery tie switch, is pulling in the solenoids to bypass the charging path momentarily. This protects the diode or battery isolator from higher than rated amperage as well a passing full amperage one way or the other. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:05 AM 8/5/2006 +0000, you wrote: >I would think the relays for the start Genset functions should run >off the gen battery only and any cross hooking could cause a path >around the diode and a failure to remotly start if house, coach >batteries are dead. >Gregory O'Connor >94ptRomolandCa > > |
08-05-2006, 00:22
Ralph,
Am I understanding correctly that the Aux. Switch when depressed sends current from the engine batteries directly to the generator starter. Depressing the Aux. Switch will not send current from the Generator battery to the Engine batteries. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 04, 2006 9:50 PM Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis batteries and the generator battery Greg: The idea of the battery tie switch, is pulling in the solenoids to bypass the charging path momentarily. This protects the diode or battery isolator from higher than rated amperage as well a passing full amperage one way or the other. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:05 AM 8/5/2006 +0000, you wrote: >I would think the relays for the start Genset functions should run >off the gen battery only and any cross hooking could cause a path >around the diode and a failure to remotly start if house, coach >batteries are dead. >Gregory O'Connor >94ptRomolandCa > > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.5/407 - Release Date: 8/3/2006 [Non-text portions of this message have been removed] |
08-05-2006, 00:34
Howard:
Current will go both ways when the tie switch is used. Engine won't start, then you hit the tie switch to get a boost from the gen set battery. Gen set won't start, hit the tie switch to get a boost from the engine/house batteries. Tie switch back to normal, separates the batteries once again via the solenoids, and charging returns through the diode or battery isolator on the gen set. Some Coaches have a Bosh relay in that circuit, so the tie switch energizes the Bosh relay and the currant flows to energize the coils of the battery tie solenoids. Some of the 90's Coaches have a three way battery tie switch. But will not go into that one until I have had a po9ot of coffee and am fully awake. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 08:22 AM 8/5/2006 -0400, you wrote: >Ralph, >Am I understanding correctly that the Aux. Switch when depressed sends >current from the engine batteries directly to the generator >starter. Depressing the Aux. Switch will not send current from the >Generator battery to the Engine batteries. >Howard Truitt >Camilla, Ga. >86 PT40 > > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, August 04, 2006 9:50 PM > Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis > batteries and the generator battery > > > Greg: > > The idea of the battery tie switch, is pulling in the solenoids to bypass > the charging path momentarily. This protects the diode or battery isolator > from higher than rated amperage as well a passing full amperage one way or > the other. > > Ralph > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 01:05 AM 8/5/2006 +0000, you wrote: > >I would think the relays for the start Genset functions should run > >off the gen battery only and any cross hooking could cause a path > >around the diode and a failure to remotly start if house, coach > >batteries are dead. > >Gregory O'Connor > >94ptRomolandCa > > > |
08-05-2006, 01:38
Ralph,
My problem is I have the old battery boilers [ new chargers on order as we speak ] and some stray current draw even when 12v master and 12v electronic master is off it is killing the batteries and it kills the Generator battery also. Can the diode go bad where it allows reverse current flow or would the culprit be the solenoid. Howard ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Saturday, August 05, 2006 8:34 AM Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis batteries and the generator battery Howard: Current will go both ways when the tie switch is used. Engine won't start, then you hit the tie switch to get a boost from the gen set battery. Gen set won't start, hit the tie switch to get a boost from the engine/house batteries. Tie switch back to normal, separates the batteries once again via the solenoids, and charging returns through the diode or battery isolator on the gen set. Some Coaches have a Bosh relay in that circuit, so the tie switch energizes the Bosh relay and the currant flows to energize the coils of the battery tie solenoids. Some of the 90's Coaches have a three way battery tie switch. But will not go into that one until I have had a po9ot of coffee and am fully awake. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 08:22 AM 8/5/2006 -0400, you wrote: >Ralph, >Am I understanding correctly that the Aux. Switch when depressed sends >current from the engine batteries directly to the generator >starter. Depressing the Aux. Switch will not send current from the >Generator battery to the Engine batteries. >Howard Truitt >Camilla, Ga. >86 PT40 > > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, August 04, 2006 9:50 PM > Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis > batteries and the generator battery > > > Greg: > > The idea of the battery tie switch, is pulling in the solenoids to bypass > the charging path momentarily. This protects the diode or battery isolator > from higher than rated amperage as well a passing full amperage one way or > the other. > > Ralph > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 01:05 AM 8/5/2006 +0000, you wrote: > >I would think the relays for the start Genset functions should run > >off the gen battery only and any cross hooking could cause a path > >around the diode and a failure to remotly start if house, coach > >batteries are dead. > >Gregory O'Connor > >94ptRomolandCa > > > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.7/409 - Release Date: 8/4/2006 [Non-text portions of this message have been removed] |
08-05-2006, 01:46
Without doing a few electrical checks I would have to assume that you have
a stuck, or bad solenoid causing the drain. The diode, usually will not cause this type of problem. Sounds like you may have a high resistance short in there; ie: solenoid contacts or cable shunted to the frame. Actually there are 2 solenoids that work in conjunction with each other and you should have the Bosh relay in your Coach as well, depending on the date it was built. Some of the early Coaches did not have the Bosh, while later Coaches of the same year did have the mod. No, go for the solenoids,, that seems to be the 97% cause. Ralph At 09:38 AM 8/5/2006 -0400, you wrote: >Ralph, >My problem is I have the old battery boilers [ new chargers on order as we >speak ] and some stray current draw even when 12v master and 12v >electronic master is off it is killing the batteries and it kills the >Generator battery also. Can the diode go bad where it allows reverse >current flow or would the culprit be the solenoid. >Howard > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, August 05, 2006 8:34 AM > Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis > batteries and the generator battery > > > Howard: > > Current will go both ways when the tie switch is used. Engine won't start, > then you hit the tie switch to get a boost from the gen set battery. Gen > set won't start, hit the tie switch to get a boost from the engine/house > batteries. Tie switch back to normal, separates the batteries once again > via the solenoids, and charging returns through the diode or battery > isolator on the gen set. Some Coaches have a Bosh relay in that > circuit, so > the tie switch energizes the Bosh relay and the currant flows to energize > the coils of the battery tie solenoids. > > Some of the 90's Coaches have a three way battery tie switch. But will not > go into that one until I have had a po9ot of coffee and am fully awake. > > > Ralph > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 08:22 AM 8/5/2006 -0400, you wrote: > >Ralph, > >Am I understanding correctly that the Aux. Switch when depressed sends > >current from the engine batteries directly to the generator > >starter. Depressing the Aux. Switch will not send current from the > >Generator battery to the Engine batteries. > >Howard Truitt > >Camilla, Ga. > >86 PT40 > > > > ----- Original Message ----- > > From: Ralph L. Fullenwider > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, August 04, 2006 9:50 PM > > Subject: Re: [WanderlodgeForum] Re: Solenoid between the chassis > > batteries and the generator battery > > > > > > Greg: > > > > The idea of the battery tie switch, is pulling in the solenoids to bypass > > the charging path momentarily. This protects the diode or battery > isolator > > from higher than rated amperage as well a passing full amperage one > way or > > the other. > > > > Ralph > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 01:05 AM 8/5/2006 +0000, you wrote: > > >I would think the relays for the start Genset functions should run > > >off the gen battery only and any cross hooking could cause a path > > >around the diode and a failure to remotly start if house, coach > > >batteries are dead. > > >Gregory O'Connor > > >94ptRomolandCa > > > > > > > > > > > >------------------------------------------------------------------------------ > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.10.7/409 - Release Date: 8/4/2006 > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
