Help Selecting Battery Charger Size...84FC
11-03-2008, 11:35
My Todd Engineering semi-smart 75 amp charger-converter has bit the
dust. As long as it was working, I didn't give chargers a second thought. It kept the batteries up and when they needed water, I watered them. Now, having to get a new one, I have been looking for the correct amp rating for the charger and am more confused the longer I look. My FC has 4-6v batteries with a combined rating of about 450 amp hours. I have seen recommendations of between 10% to 25% of battery AH for the charger rating. That would be somewhere between 45-112 amps. Well that's not much help! I think when this thing was new it came with two 75 amp chargers...that's off the chart. I do dry camp occasionally and like to run the generator about one hour in the morning and again in the evening. The 75 amp I had seemed to do OK with that. What size charger works for you? I don't always so the right thing, but I at least like to know what the right thing is. Thanks, David Hollis 84FC35 Springfield,IL |
11-03-2008, 14:52
50 or 55 amp works, just be sure they are smart chargers. I got mine from Progressive, check the Hot Deals. If you need more info. email me and I'll get out the details and let you know.
On Mon, Nov 3, 2008 at 3:35 PM, dthollis1961 <"dthollis@sbcglobal.net"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
