Supplemental breaking systems
10-03-2006, 14:27
Hi group,
We have a new Honda Element that we will be towig when we fulltime out of here in Tacoma in Oce 07. What supplemental systems are you guys running? I see lots of states that require such a system if over 3,000 lbs. The Element weighs 3,500 lbs. Canada is fine as limit is 4,000lbs, but worry about here in states. If I get in an accident, I'm sure the insurance co. will look for any excuse to deny the coverage. Thanks, Bob Lawrence 84 PT36 Tacoma, Wa. |
10-03-2006, 15:04
Bob,
I just installed the SMI Silent Partner SmartBox, wireless communication between vehicles. I wanted a unit that stayed in place, nothing to hook up or take out before/after a trip. I haven't been out on the open road yet, but will be next week. Several forum members have one type or another of many SMI units available. They will chime in I'm sure. If I remember I'll report back after I have taken a short trip. Installing the unit was pretty much straight forward, nothing complicated. About 4 hours time...well more because the neighbors stop in to see what I'm up to and the talking adds to the time. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Bob Lawrence wrote: >Hi group, >We have a new Honda Element that we will be towig when we fulltime out >of here in Tacoma in Oce 07. > >What supplemental systems are you guys running? > >I see lots of states that require such a system if over 3,000 lbs. The >Element weighs 3,500 lbs. > >Canada is fine as limit is 4,000lbs, but worry about here in states. >If I get in an accident, I'm sure the insurance co. will look for any >excuse to deny the coverage. > >Thanks, >Bob Lawrence >84 PT36 >Tacoma, Wa. > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
10-04-2006, 05:09
I just ordered an SMI system for my vehicle. It uses the toad's
regular power braking system with a vacuum pump. Minimizes stress on the toad brakes. See <http://www.smibrake.com> for details. M&G Engineering system was also interesting ... it ties into the coach air brakes. Eventually, I decided on the SMI system because I was uncomfortable about splicing into the coach air brake lines. See <http://www.m-gengineering.com> for details. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Oct 3, 2006, at 7:27 PM, Bob Lawrence wrote: > Hi group, > We have a new Honda Element that we will be towig when we fulltime out > of here in Tacoma in Oce 07. > > What supplemental systems are you guys running? > <snip> [Non-text portions of this message have been removed] |
10-04-2006, 06:08
Bob,
I installed an SMI system in my Jeep. I liked it because it required only one modification to the jeep which was to install a one- way valve and a tee in the vacuume line, and no changes to the coach. I have taken several short trips with steep hills and it seems to work fine. The difference between the M&G and the SMI function is that the M&G applies the brakes whenever the coach brakes are applied proportional to the brake air preasure, while the SMI uses an inertial measurement system and only applies the brakes when you are really trying to slow down quickly (it is adjustable for sensativity). The theory is that the brakes only need to be applied in heavy stopping situatuins and not when just slowing or controling speed on a hill. I also purchased the breakaway feature so if the toad gets loose it will put on the brakes. I think the toad brakes will last much longer this way and since the Jeep is a fraction of the coach weight I doubt it will significantly effect the life of the coach brakes. Setup is simple, turn it on. (and connect the breakaway cable to the coach if installed) Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi group, > We have a new Honda Element that we will be towig when we fulltime out > of here in Tacoma in Oce 07. > > What supplemental systems are you guys running? > > I see lots of states that require such a system if over 3,000 lbs. The > Element weighs 3,500 lbs. > > Canada is fine as limit is 4,000lbs, but worry about here in states. > If I get in an accident, I'm sure the insurance co. will look for any > excuse to deny the coverage. > > Thanks, > Bob Lawrence > 84 PT36 > Tacoma, Wa. > |
10-04-2006, 06:22
Bob:
I installed the SMI system as has Pete Masterson. I have been very pleased with this system. I am pulling a Ford Explorer and have had no problems once I figured out how to get to the brake light switch wiring. Good Choice. Tim Spreadborough '86 PT38 Oregon City, OR "End of the Oregon Trail" -------------- Original message ---------------------- From: "Bob Lawrence" > Hi group, > We have a new Honda Element that we will be towig when we fulltime out > of here in Tacoma in Oce 07. > > What supplemental systems are you guys running? > > I see lots of states that require such a system if over 3,000 lbs. The > Element weighs 3,500 lbs. > > Canada is fine as limit is 4,000lbs, but worry about here in states. > If I get in an accident, I'm sure the insurance co. will look for any > excuse to deny the coverage. > > Thanks, > Bob Lawrence > 84 PT36 > Tacoma, Wa. > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
