Tag Axle Wheels
10-06-2006, 18:59
Tag Axle Wheels
Just a curiousity - I have noticed that the tag wheel hubs on 2000
model LXi 43 coaches have the "turned-out" hub, and some later models - as well as earlier than 2000 - are "turn-in." Are these steerable tags? Thanks. Joe (Pappy) Hagan St. George, UT Wannabe |
10-06-2006, 21:19
Tag Axle Wheels
Yes, they are a version of steering that Bluebird introduced for a short
period of time. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-07-2006, 00:22
Tag Axle Wheels
Steerable? Fixed ? Caster?
GregO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Joe Hagan" > > Just a curiousity - I have noticed that the tag wheel hubs on 2000 > model LXi 43 coaches have the "turned-out" hub, and some later models > - as well as earlier than 2000 - are "turn-in." Are these steerable > tags? Thanks. > > Joe (Pappy) Hagan > St. George, UT > Wannabe > |
10-07-2006, 04:17
Tag Axle Wheels
In 2000 an active steerable tag was standard on the WL. Some 2000
Wanderlodges have had the steerable tag removed at no cost, the turned-out wheels is the indicator. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Yes, they are a version of steering that Bluebird introduced for a short > period of time. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
