Follow up: 89-97 clearance lights and tail lights
10-10-2006, 13:28
Question....since the old Peterson lights are single wire, and self
grounding, what is the fix for the two wire lights? Where do you attach the
ground
since there is no original ground wire at each light fixture?
Hmmm
Kevin McKeown
Yorba Linda, CA
1986 38' PT
10-11-2006, 00:07
You have two choices on the grounding
1 run ground wires back to light switch a large job but the most
dependable and politicaly correct
2 make a small loop and ground through the mounting screw of the lights
this is the way that it was originaly done on the one wire lights even
though there was only onr wire this base of the light grounded the
ground completeing the circuit
one thing to watch out for with leds is that the light must be
connected in the correct polarity or it will not work
Stephen 77fc35
attach the ground
> Hmmm
> Kevin McKeown
> Yorba Linda, CA
> 1986 38' PT
