Battery connect solenoid location
10-11-2006, 02:13
Does anyone know where the actual physical location of the battery
connect solenoid (connects coach batteries with generator battery) is. I suspect that mine is not working. Tom sorrentino Bedford Hills, NY 1987 PT38 |
10-11-2006, 06:55
Hi Tom,
The isolator circuitry and solenoid is usually silver/chrome in color and about three inches long and one inch in diameter and generally mounted vertically. Typically has three electrical connectors; left, top and right, with obvious, heavy-gauge, wire connections. Most gen solenoids I've located are in the gen battery compartment; however I have seen them in the engine compartment mounted beside the coach/engine isolation solenoid. If mounted in the engine compartment, look on the vertical wall, toward right, rear of engine as you would look from an open engine compartment, and about 3 feet left of curbside edge. Unless you want to climb onto the top of the engine LOL, you will access it from the curbside opening above the batteries. Whereever it is located, be careful disconnecting the wiring (i.e. support the wiring as you unscrew nuts/screws) as many have their diode wires connected between/among the connectors and among heavier wire connectors, and the diode wires can easily break off from the diodes themselves. John Suter --- thomas_sorrentino wrote: > Does anyone know where the actual physical location > of the battery > connect solenoid (connects coach batteries with > generator battery) is. > I suspect that mine is not working. > > Tom sorrentino > Bedford Hills, NY > 1987 PT38 > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-11-2006, 14:55
Tom,
Try looking in front of the front passenger tire, mounted on a bulkhead, near the rear of the air step. You have to get on your back, slide underneath the air step, and look up. that's where mine is on my 86 38' PT (and I had to replace it too, along with the big diode in the battery charger compartment (curbside compartment, in front of the battery/engine compartment side grille). Good luck... Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
10-12-2006, 02:33
Kevin,
Thats where I was thinking it might be, but still have not found it there. I did find two insulated posts with battery type wire going to them. I'll need to physically trace them. There is a solenoid right in the most forward drivers side bin, where the gen. slide tray controls are. I'm wondering if thats it? I do have the large diodes in the back. Why did you have to replace one of those? Tom Sorrentino Bedford Hills, NY 1987 PT38 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Tom, > > Try looking in front of the front passenger tire, mounted on a bulkhead, > near the rear of the air step. You have to get on your back, slide underneath > the air step, and look up. that's where mine is on my 86 38' PT (and I had to > replace it too, along with the big diode in the battery charger compartment > (curbside compartment, in front of the battery/engine compartment side > grille). > > Good luck... > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
