Racor experiences
11-10-2006, 05:23
Racor experiences
Anyone have experience using the Racor "High capacity spin-on series"
filters with the attached water bowl? My fuel/water seperator is a
ConMet brand that is no longer made and leaks at the connection. There
are currently a primary and secondary filters in the engine bay with
standard spin-on filters. Would the Racors spin-on filters with the
attached bowls work for removing the water? How often have you had to
drain the water from the filter and how much water?
Troy Tikalsky
1986 Newell DD8V92
